SOURCE: control locked
Hold the 'options' and 'select' buttons down at the same time for several seconds, the thing will unlock.
And rate me pl..................
SOURCE: The drum wont hold water. it goes right out the draim
The drain needs to be above the actual water level or it will run out, the pvc should be above this point in order for the hose to get air and not act like trap and run out all that comes in,< woud suggest going to hardware store and getting piece to add on to 4 inch section with a coupler and washer drain cap>. they will cut to length, < take measurement of pipe size and length needed to get just bellow height of washer top, pvc goes together by cleaning and glueing, if the 4 inch piece has angle cut then it will have to be cut to strait line for good seal.
SOURCE: Amana front load washer door wont unlock
Hi.
Nd is drain error.
Check inside the control assembly, you may have a technical diagram with instructions pocked in there.
You will need to check the drain pump hose for blockage.
If that is not enough to fix the problem, then the fault may be the pressure switch, the pump, or the control assembly.
In that case the best thing to do is calling the support number listed in the owners manual to contact Amana.
SOURCE: Have an older Maytag top load washer. Probably 10
This could be a bad timer. Try changing setting on timer and truing it on. One thing for sure you have a dead short... This could be the timer or the motor or it could be a wire inside the cabinet shorted out... There should be 2 clips on the top front of machine that hold the top douwn use a putty knife or other thin but stiff object to pust in on those clips while pulling up on top at the same time then you can fold the top back out of the way and just look for anything unsuual. Burnt/ broken wires loose wires etc... The front will need to be removed to observe motor area... Usually 2 screw at top left and right the pullout and up... Smell around the motor for that burned rubber smell.
Please let me know if I can do anything else to help
Washer Not Filling:
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
Hi
It seems that something is clogged in the drain pump
assembly and you have to clean it to solve this issue. After cleaning if the
issue returns then test the door lock assembly, if bad it should be replaced. Hope
this helps...please post back for further assistance.
Daniel
