either the drive belt which connects the crank shaft pulley to the top of the transmission pulley has failed, or the hydrostatic transmission has failed. the first is easy to spot, a broken belt, and fix; the second problem basically means you will spend more to buy a new transmission than another mower will cost.
Deadeye, the problem isn't with the keyboard but with the motherboard overheating. Grab a cheap laptop cooler from geeks.com and you will find that this will keep the laptop cool enough to play a game without key creep taking over. The DV9000 laptop from HP is notorious for overheating and dying due to improper ventilation and you need a laptop cooler no matter what else you do. Otherwise your laptop could simply overheat and the solder will separate.
If it's a stander transmission, could be pressure plate getting weak, only repair is to replace it with a clutch kit, kit will have disk, pressure plate and bearing.
