Dishwashers Logo
Posted on Sep 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No water entering machine. machine had stpped, as there was a piece of cling film blocking the outlet, this has since been removed but machine will not wash.
Level 3:
  • Bosch Master 17,130 Answers
  • Posted on Sep 01, 2011
Bosch Master
Level 3:
Answers
17130
Questions
0
Helped
3631703
Points
52372
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect but in this case the inlet and outlet must be checked.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Not cleaning and leaves film
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers plates and make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe or the pump or selector valve. If possible back flush through the outlet pipe and try draining the machine once more before using it again.
Jun 05, 2011 • Dishwashers
My maytag dishwasher is leaving a film on my dishes how come?
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 17, 2011 • Dishwashers
Everything in dishwasher is coming out with white layer of film ?
What`s the function of starboard outlet spout ?
The water squirter out the side is there to show you that there is cooling water going through the engine. If the outlet spout stops shooting water out the side you need to stop the engine and investigate. I have had mine stop shooting water. I stopped the boat and blew air through the hole backwards to clear the tube. One time I had to pull the hose off the motor(where the squirting water enters a hose to the outlet spout) and push a piece of wire into the engine outlet hole to clear it. Fortunately , the motor was never in any danger of overheating only the wizzer hole was blocked , water was still cooling the motor. Again if the outlet spout stops shooting water turn off the motor and make sure water is entering and cooling the motor.
Washing machine does not drain so there is a dirty water stuck in the machine .it is a bosch washing machine
Please check the outlet pipe connection. See that the pipe is not bent or twisted. Also remove the outlet pipe and check the outlet opening. See that it is not blocked because of dirt or may be a piece of cloth is stuck in the outlet opening. Clean it.
10helpful
2answers
Could you please tell me what error codes 21 and 6 relate to on a Winterhalter GS502 dishwasher. Many thanks. Barry CER
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Mar 29, 2010 • Dishwashers
7helpful
Water coming from soap compartment. is there someway to clean the dryer fluff from machine
It sounds like the water outlet is blocked. Same happened to me.
Unplug machine from mains.
Remove panel located on the rear near the base of machine.
In the bottom right corner you will see the outlet pipe and the pump.
Remove grey outlet pipe to get better access.
Undo the large jubilee clip where the black pipe joins the drum outlet.
Inside this pipe is a white plastic cage filter.
Check to see if anything is blocking it.
There is a heavy film on my dishes. I have a rinse in it but I don't think it is being used and I use Cascade gel to wash them?
A heavy film can be the product of bad water conditions, bad cleaning action from the machine, incorrect/inadequate chemistry, and even water temps being too low.
Start by washing some of the dishes by hand to determine if the film can be removed. Use a quality detergent and some elbow grease. If film can be removed, test the machine for proper washing action. I like to do this by coating the inside of several glasses with mayonaise and placing them strategically throughout the machine. Run a cycle and ensure ALL mayonaise is removed. Is mayo removed? If no, check for plugged wash arm jets or screens. If yes, check for good water temps. 120F or higher is best, depending on machine type/model.
If machine is good and film is removed by hand, then you either have a water problem (water hardness, TDS, etc), a temp issue (raise temps above 120F), or a procedural issue (improper loading of wares, inadequate/insufficient detergent, too much food soil entering dishmachine).
Hope this helps,
Kermit
3helpful
Water Leaking
Dear Customer,
The likely reasons for a leaking AC are...
1) Improperly installed.
A window air conditioner must be slightly lower at the rear than the front. This allows the water being removed from the room to drain to the back of the machine. A difference of one inch is sufficient. This is always the first thing to check. Many are improperly installed in the haste to get relief from the heat. If installed too low at front the water will flow into the room rather than outside. If installed too low at rear, water can roll out front edges before has chance to exit towards rear drain.
  1. Icing up.
    Water being de-humidified can turn to ice if there are problems with the cooling system. There are many reasons for an air conditioner to produce ice. Remove front grille while machine is operating. If ice is present on the cooling coil you will probably need service. For more information see our other article: Why window Air Conditioners Ice up.
  1. Air leakage around air conditioner.
    If warm air is able to enter around the air conditioner it will encounter cooler, dryer air. When they meet condensation will occur. If water leaking from front of air conditioner inspect to see if dripping from body of machine, or water droplets clinging to front area. To test, operate machine for 30 minutes and then use flashlight to check under front edge of base. Small water droplets here indicate an air leakage problem. Add foam insulation to stop warm air from infiltrating.
  1. Drain hole blocked.
    Rear of air conditioner base has a drain hole or groove to allow water to escape. If becomes blocked water can back up. To test, operate machine for 30 minutes and then inspect if draining properly. If appears blocked use a small piece of wood to open drain hole at rear of metal base. CAUTION: Never be tempted to drill holes into the air conditioner body to relieve water pooling. Severe damage can result.
  1. Internal drains blocked.
    There are small passageways that allow water to drain from front of air conditioner to the rear. If they become blocked water will pool at front of machine and overflow onto floor. If this happens the air conditioner will require removal from window and servicing.
  1. Outside temperature too cold.
    This occurs at end of cooling season. If outside temperatures drops below 60 degrees Fahrenheit at night the cooling coil may ice up. If no leakage at bedtime but water in front of machine in morning, suspect this problem. If this problem suspected turn off machine before bedtime and restart as day warms. Alternately, operate machine at night with selector switch in ‘fan only’ position. This will circulate room air during night but not allow cooling.
Hope u find this useful. I'll be thankful if u could rate this. thank you.
5helpful
3answers
W640 - Water Outlet Fault
I solved this problem this morning, after several months with intermittent "water outlet fault" error messages.
Our pin trap was cleared many times over the months. The propellor turned freely. However, the problem persisted.
So I unplugged the machine, removed the back panel (8 or so hex screws) and located the point where the drainage hose meets the water draining pump. I then separated the hose from the pump and found 2 United States 10-cent pieces lodged together with gunk that effectively blocked the drainage hose. 10-cent pieces ("dimes") are the perfect diameter to get stuck there and not appear in the pin trap where you could easily see and remove them.
Three loads later, the machine is working according to spec. Hope this helps.
Apr 09, 2008 • Asko W640
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
