I have also faced this problem and it can happen due software and hardware issues. But there are some simple solutions to fix this problem. Just refer this guide to fix windows generic non pnp monitor problem Windows Generic Non PnP Monitor Problem Fix or Solution
This tends to indicate that the monitor isn't conveying it's specific information to the PC. This usually happens if the driver for the video card isn't quite right or is all together wrong.
You aren't getting bi-directional communication from the VGA card (yes, they actually do RECEIVE as well as send signals).
Look to your video card driver, and make sure it's the right one for the operating system you are using, and also that it's updated.
I see you are having issues with you LG monitor.
What type of video card do you have on your computer? if I may ask.
And also did the LG Monitor come with a disc to install the Monitor.
The VGA means it is using VGA a a mode or type of cable connection for the Video, what cable are you using? are you using an HDMI connection for the Monitor/LCD or is it the Blue Cable on both ends if it is the Blue Cable then that is using VGA so it will say on VGA meaning it detects the video connection from that cable.
Are you asking because this shows every time you turn the LCD monitor ON , is that correct, if that is the reason it is normal.
The question I see is incomplete? and when you? what happens?windows detected my monitor as generic non pnp monitor and when i installed the inf file for lg monitor and updated and rebound to generic non pnp monitorit says device on vga and when i
