Yamaha RX-V663 Receiver Logo
ruwan Posted on Mar 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My RXV663 does not power up Ive had it for 2 yrs, I kept in storage inoperative for 3 months (unplugged and completely disconnected), when I connected it up, it would not power up, no clicking sounds, no display, nothing. I gave it to my dealer here in sri -lanka but i thing im being ripped off. They've had the amp 3 months now but still cant find the problem. they said they swapped the crystal 20mhz, the cpu, no luck now they are planning to swap the whole P.C.B Digital and see if this works - im getting the impression im being ripped off the pcb digital alone costs more than the amp. Could it be that protection ciruitry opereated 3x consecutively and disabled the power? if yes how can that be fixed any ideas on part nos? I simply cannot trust the dealer here in sri lanka please advise
Level 3:
  • Yamaha Master 19,187 Answers
  • Posted on Mar 18, 2017
Yamaha Master
Level 3:
Answers
19187
Questions
0
Helped
4345402
Points
82261
It makes no sense that the dealer cannot find the problem. There are several areas they could be looking at and are not. The service manual is available,
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Dec 11, 2006
SOURCE: Should I just Buy a new one?
You have a bad power supply or the audio output circuit has a short in it. You are correct by saying its probably betterv off getting a new unit. Most likly cost you more then a brand new shiny unit would . Good Luck PS Please do not forget to rate this thread
Michael Borelli
  • 979 Answers
  • Posted on Nov 05, 2008
SOURCE: Yamaha RX V861 - Phillips DVD - No sound via digital coax
Does your TV support "Line In" or "Aux" or "External"? if so plug your "Low end" DVD directly into the back of the tv and verify that you Can get audio. Quite a few DVD players do have a mute feature. Be sure this is turned "off"...accordianman
Anonymous
  • 146 Answers
  • Posted on Jan 03, 2009
SOURCE: amp freezes when tv channel is changed
Are you using the HDMI for video AND audio or just video? Are you using the reciever as the video switcher by routing your devices into the amp and then from the out of the amp to the TV and then back to the amp from the TV HDMI output and the digital output? You may have a loop going on and the amp can't handle it.
If you are coming out of the TV with both HDMI and digital hooked to the same input selection on the amp and have the amp set for auto signal select, it could be throwing the amp for a loop and causing it to freak. From what I can see in the specs for that amp it has 2 HDMI in for connecting a HiDef Sat/Cable box, a DVD or Blu-Ray player or a gaming console, and then 1 output to the TV. HDMI handles both audio and video. Disconnect the digital cable and just use the HDMI for both audio and video.
The optimal set up would be as follows:
With a cable or sat box with HDMI out, go to the HDMI input to the TV. From the TV use either HDMI OR digital to the amp, not both. If you have Blu-Ray or HDMI DVD, connect that to the other HDMI input on the TV.
If the TV has only 1 HDMI input then connect the Cable or Sat box to one of the amp HDMI inputs and the Blu-Ray/DVD to the other and then from the HDMI out to the HDMI in to the TV with NO audio cable from the TV to the amp. Then use the cable remote to change channels.
See if one of those connection maps works for you.
If you need more help, let me know. Include the TV model and the digital audio cable interface type, whether it is optical or coax. It would also help knowing if you are using a Satellite or Cable box and which one it is.
Cheers
Anonymous
  • Posted on Aug 06, 2009
SOURCE: yes i am not getting dolby digital signal or
Dude, I had the same problem. Just go at yours DVD player and change the audio setup from PCM to Bitstream. PCM is only 2 channel!!
Anonymous
  • 5807 Answers
  • Posted on Sep 24, 2010
SOURCE: yamaha htr-5460 receiver; unit will
I just hope you have read my earlier post if not I will post again
1helpful
2007 Buick Lacrosse Door Locks not working getting weak
Important: If all 3 passenger door locks are inoperative from both door lock switches, test the unlock control circuit between the splice and the BCM for an open.? Do you know how to do this ? Looking at a wiring diagram an using a DMM - digital multi-meter ?
Free wiring diagrams here http://www.bbbind.com/free-tsb , enter vehicle info. year , make , model an engine size . under system click on body & accessories , then under subsystem click on power locks . Click search button then the blue link . Or maybe your best bet mite be to take it to a qualified repair shop. You would need factory service repair info. to find splice location .
Power Door Locks Inoperative - Passenger Door
Step
Action
Yes
No
Schematic Reference: Door Lock/Indicator Schematics
Connector End View Reference: Vehicle Access Connector End Views
DEFINITION: One or all 3 of the passenger door lock actuators do not operate, or, the front passenger door lock switch does not operate.
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
Verify that the Power Door Locks Inoperative - Passenger Door fault is present.
Do the door locks operate as described in Power Door Locks Description and Operation ?
Go to Testing for Intermittent Conditions and Poor Connections
Go to Step 3
Are all 3 of the passenger doors locks inoperative from both door lock switches?
Go to Step 10
Go to Step 4
Install a scan tool.
Close all of the vehicle doors.
With the scan tool, observe the Right Front (RF) Door Lock Switch parameter in the Data Display, Inputs list of the body control module (BCM).
Operate the front passenger door lock switch to both the LOCK and UNLOCK positions.
Did the parameter change to both the LOCK and UNLOCK states?
Go to Step 7
Go to Step 5
5
Important: If the 3-amp fuse of the jumper wire opens when the jumper wire is connected, test the appropriate signal circuit for a short to battery positive voltage.
Disconnect the harness connector of the front passenger door lock switch.
Connect a 3-amp fused jumper wire between the lock switch lock signal circuit of the harness connector and a ground.
Observe the RF Door Lock Switch parameter.
Connect the 3-amp fused jumper wire between the lock switch unlock signal circuit of the harness connector and a ground.
Did the Scan Tool parameter change to the both the LOCK and UNLOCK states?
Go to Step 6
Go to Step 8
6
Connect the 3-amp fused jumper wire between the lock switch lock signal circuit and the ground circuit of the harness connector while observing the appropriate Scan Tool parameter.
Did the Scan Tool parameter change to the LOCK state?
Go to Step 11
Go to Step 14
7
Disconnect the harness connector of the inoperative door lock actuator.
Connect a test lamp between the door lock actuator lock control circuit and the door lock actuator unlock control circuit of the harness connector.
Operate the front passenger door lock switch to the LOCK and UNLOCK positions.
Did the test lamp illuminate in both positions?
Go to Step 13
Go to Step 9
8
Test the signal circuits of the front passenger door lock switch for a short to ground or an open. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
Go to Step 18
Go to Step 12
9
Test the lock control circuit of the inoperative door lock actuator for an open. Refer to Circuit Testing and Wiring Repairs .
Go to Step 18
Go to Step 10
10
Test the unlock control circuit of the inoperative door lock actuator for an open. Refer to Circuit Testing and Wiring Repairs .
Go to Step 18
Go to Step 12
11
Inspect for poor connections at the harness connector of the front passenger door lock switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 18
Go to Step 15
12
Inspect for poor connections at the harness connector of the BCM. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 18
Go to Step 16
13
Inspect for poor connections at the harness connector of the inoperative door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 18
Go to Step 17
14
Repair the open ground circuit of the front passenger door lock switch. Refer to Circuit Testing and Wiring Repairs .
Did you complete the repair?
Go to Step 18
15
Replace the front passenger door lock switch. Refer to Front Side Door Lock Replacement .
Did you complete the replacement?
Go to Step 18
16
Replace the BCM. Refer to Control Module References for replacement, setup, and programming.
Go to Step 18
17
Replace the inoperative door lock actuator. Refer to Front Side Door Lock Actuator Replacement
Go to Step 18
18
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
No display
Turn it off completely, disconnect power cable.... Reconnect printer power cable directly to the power board after that turn in ON ...
Thanks
Our machine (now nearly 3 yrs. old) has been leeking out the bottom and from the steamer until all the water is completely gone for the past month. I fill it with enough water to make 2 capps. in the...
sealing between heating element and boiler-body leaks the water - and it has probably shortcut the electricity by now: disconnect the powerplug immediately - and exchange the sealing
Hav a dell inspiron 530 w pentium dual core processor ... bn n storage 2 to 3 months..power up w a blue light ..yellow light inside...fans works ..no usb power.. no bios screeen or a,y start up formations...
Try opening the case and unplugging all circuit card/mem modules/cpu and re-seating them in their sockets...may be during storage that heating /cooling cycles caused connections to go bad
Printer won't start
1. completely unplug power cord from wall socket,
2. unplug power cord from printer
3. unplug printer cable completely from computer
4. unplug printer cable completely from printer.
5. let printer stay disconnected for approx 1 minute
Now securely:
1. reconnect the printer cable to the printer.
2. reconnect the printer cable to the computer
3. reconnect the power cord to the printer
4. reconnect the power cord to the wall socket
turn printer on
You may find that a connection has simply worked itself loose over time.
2helpful
Sub zero particles in ice from ice maker
This issue occurs if your Ice Maker is not clean or have dust particals inside, follow the below steps in order to clean it properly:
Step 1 Lift the power bar located above the ice maker storage tray.
  • Step 2 Unplug the refrigerator.
  • Step 3 Allow the refrigerator and freezer to defrost. This will melt any large blocks of ice that have accumulated in the ice maker.
    Clean the Ice Machine
  • Step 1 Remove the ice machine storage tray.
  • Step 2 Dump any water in the ice machine storage tray.
  • Step 3 Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
  • Step 4 Sanitize the lines of the ice maker. Consult your manufacturer's directions for steps to do this, because it's not available on all models.
    Reassemble the Ice Maker
  • Step 1 Replace the ice machine storage tray.
  • Step 2 Plug the refrigerator into the outlet to restore power.
  • Step 3 Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
  • 0helpful
    HLN507W Samsung DLp Horiz. lines
    it sounds like the dmd board is failiing
    Razr Inop
    you need to take the phone back and have it replaced for a new one.
    Oven lock engaging and disengaging
    Unplug the oven from the outlet, and wait 24 hours or overnight, and plug it back in. It should unlock and work ok.
    Dec 04, 2007 • Ovens
    Top Yamaha Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Paul Bade
    Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
