1.
Downoad [ANT] Simple Ant Simple.zip
2. If you
have Nokia PC Suite running, be sure to close it by exiting from the taskbar
icon.
3.
Extract [ANT] Simple ] and run Simple.exe located in the folder
4.
Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when
prompt a message in your pone.
5.After
you've connected your phone, Click "Read Info"
6. On the
MAIN tab, click on GET. Your phone IMEI number and model should be displayed on
the bottom panel as shown below
7. Now
click on the SERVICE tab and click on GET button under USER CODE
8. Your
security code should now be displayed on the right side of the application
window.
For details see here How to Generate Your Phone Security code..Only for Nokia bb5
Thanks For visiting Fixya
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel as shown below
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.
If you could not understand How to Generate Your Phone Security code..Only for Nokia bb5
FOR OTHER MULTIMEDIA NOKIA PHONES: Here you can't format yourphone,but you can reset it; For that,go to;SETTINGS-RESTORE FACTORY SETTINGS- AFTER CLICKING IT, your phone will ask a securitycode there you can type your code.then it wil format and restart. "IF YOU THINK MY SOLUTION IS HELP FULL TO YOU,THEN DON'T FORGET TO RATE ME"....THANK'S
