Question about T-Mobile Sidekick ID Cellular Phone
Phone wont charge
When i put my sidekick onto the charger the sidekick isnt charging. I dont know y. Its not the charger, because it works on my friends phone, and when i charge it the orange light dosent glow. Whats the problem?
  • 1 more comment
  • Anonymous Sep 11, 2008
    My phone also doesnt charge, sometimes the light goes on but It does nothing for the battery and it make me angryy.
  • Anonymous Dec 24, 2008
    i know this may sound really dumb, but which of the holes is the charging hole?
    because there is one next to the power button and one by the roller.
    Mine wont charge either :( when i plug in a charger in one hole the orange light comes on but nothing happens, and if it was charging wouldnt the battery warm up. It isnt doing anything. PLZ HELP!!!
  • Anonymous Jan 26, 2009
    i have the same problem, and sometimes when i toss my phone on my bed or even randomly when im holding it, it will turn off and restart. it's really weird..
    President:
  • 625 Answers
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Posted on Sep 30, 2008
  • Terry Fritsch
    Terry Fritsch Dec 26, 2008
    chanisanger
    The orange light comes on even if the charging port is bad. That is what is so frustrating about it. It looks like it is working but it is not.
    Here is an updated link to a less expensive charger to help you do a work around.
    Sidekick ID Battery Cradle Charger
6ya staff
SOURCE:
My sidekick 3 does not charge i have 2 press on
no there is not it sounds like the connections inside have worn so the charger isnt chrarging. here is a link to buy one http://www.gyvergear.com/PayPal/sidekick/SK3TWN/index.html
Oct 06, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
My sidekick 3 wont go past BATTERY LOW! PLEASE ALLOW DEVICE TO ..
turn off your phone. then remove the battery for 5 minutes. also make sure your charger is not plugged in. then put the battery pack into the phone. it should clear up. also you might have over charged the battery. another solution is to buy a new battery pack and if that does not work your phone is acting up on battery basis
Jan 20, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Can get it to chanrge (this is brand new)
remove the back cover and make sure the battery is inserted properly
Jan 10, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
If the orange light is coming on, but not charging the sidekick then the charger port is probably bad.
It's about 80 dollars to fix at cellulardr or you can do a work around and charge the battery seperate from the phone.
check out the charging cradle here:
Sidekick 3 spare battery charging cradle
Dec 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My Sidekick 3 wont turn on.
the phone needs a new main-board or reflash the board to get it up and running again.
Jun 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick ID.
try a friends battery if that doesnt work then dont buy a battery and sometimes reseting the phone may work like turn the screen to 90 degress and put an earing or pin inside the reset whole
Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick ID Cellular Phone Logo
247 people viewed this question
Top T-Mobile Cell Phones Experts
Ekse
Trimesh
Damen Wong
Damen Wong
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
