Question about Samsung LTN1535 15 in. HD-Ready LCD Television
Vertical lines on screen when viewing
My Samsung LTN1535 has 3 sometimes 4 vertical lines on the screen when I view it. There are 2 white lines and 1 blue line and sometimes 1 purple line. Is there a way to eliminate these lines?
  • 11 more comments
  • Anonymous Dec 24, 2007
    green and white some blue lines on screen
  • Susan33 Jan 02, 2008
    I have the same problem. The lines are on the right side of the screen. Red, blue, yellow and a number of other colors. I have unplugged it and they are still there. I do not have any other electronic devices attached. The tv is a year old and of course the warrenty just expired. HELP
  • Anonymous Mar 02, 2008
    one black vertical line
  • Anonymous Mar 07, 2008
    I have an Ultravision 50 in plasma, and when I use it for more the 1 hour, one red line start blinking in the top left side of the screen ( 1 inch width and 5 in long vertical line) could you have an answer for this ?.
  • justAuser May 12, 2008
    i have a PD-4225 plasma that has 2 vertical black bars on the left half of the screen regardless of which input is selected on the unit. I only have the "component" cable connected from a Denon receiver connected to the panel.
    The same problem occurs when connected to DVD, Direct TV or VCR or if nothing is connected. you can still see the black bars on the static screen with no inputs.
  • Loganwolf Jul 14, 2008
    My Mitsubishi PD-4225 has a black vertical line on the left-center of my screen, looks like someone placed electrical tape on the screen. It appears and disappears. Why is that? and how do I fix it?
  • Anonymous Jul 14, 2008
    purple line
  • ombhakti Jul 18, 2008
    This problem just started with our panasonic 58inch plasma tv, which is 10 months old. It is definitely the tv, and our dvd player is plugged into the tv, not the other way around. No matter what fixes we try, the left-of-center black vertical bar stays. We have narrowed down that it is just that tv, and therefore not our cable, not our wii, and not our dvd player. I don't even know what you mean by a dvd guard.... we do not record anything.
  • savijhero Oct 03, 2008
    I have this problem except that the purple lines are also images and change with what is currently being displayed on the tv. Sometimes its bad sometimes its really bad.
    Please help
  • tisuvi
    tisuvi Jul 14, 2019
    It was never so easy to translate your dreams into reality by just working online living at your home. Spend few hours in working and get your high share. It’s awesome site offering you best answer of your problems. Here is........ www.jobsthings.com
  • 123go 123go
    123go 123go Jul 15, 2019
    https://tamirep.com/product/%d8%ac%d9%88...
  • 123go 123go
    epson l565 ink
    epson ink 502 vs 664
    epson ink 512
    epson ink 500ml
    epson ink 544
    epson ink 522
    epson ink 50
    epson ink 545
    epson 5 ink printers
    epson 5 ink cartridges
    ink epson ???
    ink epson ??? price
  • 123go 123go
    http://bit.ly/2NUNzHX
    Sniper:
  • 80 Answers
If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. Joe Weibel
Posted on Feb 12, 2007
    New Friend:
I have vertical lines threw out my screen whats the problem.
Posted on Apr 08, 2010
  • Ronald gonzales Apr 08, 2010
    Anyway to fix it.
  • Romz Rodriguez Jan 03, 2015
    try watching dvd, if its not happening on dvd, then it is the source connected to the tv
  • 3 Answers
I had a purple line on my tv about 2 inches from the left side that ran from top to bottom. After freaking the F out, I unplugged everything before going to bed. I plugged it all back in in the morning and it was still there. I was about at wits while disconnecting everything again and noticed that when I messed with the cable splitter that went into the TV and cable box the line disappeared. I then noticed specifically that it had to do with the grounding screw on the splitter. I just tightened it down all the way and tightened all the connections and the filthy purple line disappeared. It worked on my brother's plasma TV as well.
Posted on Aug 03, 2007
  • tim sayre Sep 05, 2013
    that is the main board
It could be a problem with your nuts. And yes, there is a direct correlation between your balls and lcd panels.
Posted on Jul 15, 2009
    New Friend:
I bought my LTN1535 at a thrift store for $20; the display had six vertical lines.
I disassembled the set to the point of removing the lcd screen from its aluminum frame. Everything in this set is modular, so it only took ten minutes. The lcd and its assembly is defective manufacture and unsecured. Heat at the upper horizontal compounds with the unsecured nature of this assembly to cause a bad electrical connection of the lcd module.
I bought five "medium binder clips" at Staples and with shears cut 1/4 inch from the clips on one surface. I removed the spring handles and installed the clips on the upper metal top of the lcd. These clips fit the aluminum frame perfectly. I reassembled the set adding the missing 4 frame screws.
The set is now the best tv I have; so much so, that I now realize that I must replace all my tv sets. The cost to fix this vertical line problem was about $2.
Posted on Nov 24, 2009
Everyone here is wrong there is absolutely notthing wrong with your tv use your remote control go to picture go to auto motion it automatic adjust tune your tv back to normal waiting period is 5 to 10min its simple as that.
Posted on Mar 14, 2011
  • 1 more comment
  • kbirch903
    kbirch903 Apr 05, 2013
    everyoe here is not wrong, that is the first step to troubleshooting. when that doesn't fix it, it is either the tcon board, panel, main board or lvds cable. if the symptoms are in the menu as well as the live picture, it's the panel or tcon or lvds cable. if it changes with the input source, it's the main board. if it is not in the menu, but is on the live picture, it's the main board.
  • 123go 123go
    New Friend:
To get rid of vertical lines in TV I simply flipped off and back on the main breaker that controls that TV and the lines went away. It was like re-setting the TV.
Posted on Sep 12, 2010
    Champion:
  • 213 Answers
You have a bad cont pcb i see this a lot in samsung and the LG.and zenith to lg and zenith are the same. if you have a red or blue line
left side or the rigth side contly pcb
Posted on Jun 11, 2008
The display driver board is overheated, need to replaced!
Posted on Jun 18, 2008
    Problem Solver:
  • 6 Answers
You have a problem with signal board attach to lcd sreen panel open tv and check the connection if this doesn't work you need to replace lcd panel
Posted on Jan 19, 2007
    New Friend:
I have a samsung LCD MODEL LN46A530P1FXZA with vertical lines only on the right side of the tv. 1 blue line and about 1 inch wide of all different color lines. When I bring up the menu screen the lines go through the menu and you can see them still. After an hour or so the lines disapear except the thin blue one. I had the clicking issue fixed when that problem appeared and it was covered free. Then almost 2 weeks later the lines starter to show up. I understand this problem has become a major issue with samsung.
Posted on Jan 11, 2013
  • Samsung Master
  • 2,010 Answers
Support SAMSUNG Australia yes connector cables fcc sheets and other suggestions sometimes is the time that its become some components out ther range by deformed capacitors you not see but a canister coldspray can most succes if it is a very young new problem with the television then the capacitors are then still somewhat self-healing if its a thermical problem by an overrange of lost capacitance someting will possible change ifspraying cold always inspect the power supply as the first beginning of the right voltage on the different points of circuits in your television. a service manual or helpfull information can be have a high priority. maybe here is also a possibility to suggest
Posted on Dec 07, 2016
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
T-Con new,
Main board new.
Cables tested
but after 10-15s after tv powers up that line appears.
Anyone has solution for this?
Vertical lines on screen when viewing - vertical-lines-screen-when-viewing-tklwhcvdukysv41jpzzw23ce-5-0.jpg
Posted on Mar 26, 2016
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Samsung Expert
  • 158 Answers
Try to factory reset your TV. press mute, 1,8,2 power on with remote to see if any changes.
Posted on Sep 03, 2015
    New Friend:
    Cheetah:
  • Samsung Expert
  • 75 Answers
Check with different sources if those lines appears on different source, tv need for repair,faulty lcd screen
Posted on Dec 28, 2014
    New Friend:
I can not believe all of the same problems with a Samsung lcd 50" screen, got vertical lines about 2 inches a part all across the whole screen, tv still works, just little lines across the entire screen. I cant believe all the post on this same problem and not any good answer to fix it, just more problems of the same nature keeps coming and no solution!
Posted on Mar 25, 2013
    read my post above
  • scadarick422
    scadarick422 Mar 21, 2014
    all i can add is that the main board is bad or connection issues. my sharp had 4 vertical lines one day i turned it on. a sharp repairmen came by and swapped out the mb board and that fixed it. also it was still under warrenty.
    New Friend:
  • 7 Answers
These white lines (horizontalor vertical) may be an issue with the DMD board. One way we can narrow theproblem down is with a simple test: bring up the TV menu on the screen. If thewhite lines are still visible trough the menu, then it’s even more probable thatthe DMD is defective; if not then the digital video can also be held accountable.If you decide to go for a new DMD you’ll have to search by part number, NOT bymodel number, the main reason is that two TVs with the same model number mehave none compatible components because they are different generation when theywhere assembled.
Also if by any chance you can’tfind the DMD sold separately, your next option is to buy the entire lightengine that includes the DMD, and obviously that’s going to be more expensive. Ifyour trying to save lots of money and you really know what your buying try eBay,you can get a really good deal, how ever if you are not familiar with TV parts,and don’t want to take a chance buying something that might not work, tryonline stores that specialize in TV parts (my personal recommendation: Discount-Merchant).
Posted on Mar 10, 2010
The answer does not relate to the problem of vertical lines.The 3 sometimes 4 vertical lines on the screen are more likely caused by a ribbon cable connection which may or may not be reparable.
Posted on Nov 24, 2007
I have the same model with the same problem. This is NOT a copy guard problem, as it is connected directly to cable and is there on all stations. All the lines are probably there all the time, just not visible with all backgrounds. It is a circuit failure that needs to be corrected by a technician. If I find a solution, I will post it here.
Posted on Jul 01, 2007
Possible ribbon cable connection on lcd panel not making all connections.My or may not be repairable.
Posted on Apr 17, 2007
    Novelist:
  • 130 Answers
Sounds like you have it hooked up threw the VCR, there are copy guards on the DVDs that do strange things to the image if its not hooked up correctly and it will record a crappy image. The best way to view the DVDs is directly from the DVD to the tv. If that is a hastle for you then you can get a switch box you hook more then one video source to the switch box then out of that to the tv. When you push the buttons it will change from DVD, game console, VCR, Camera etc. The blue line at the bottom is one major indication of copy guard. Do a search on "macro vision: or DVD copy guard, on google and read about it. There are boxes you can get to bypass this but you didnt hear that from me... ;)
Posted on Apr 10, 2006
4 Suggested Answers
SOURCE:
SOURCE: vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Posted on Apr 21, 2008
tvservice306
  • 458 Answers
SOURCE: red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Posted on Sep 04, 2009
  • 98 Answers
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Posted on Feb 06, 2009
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Have a 50 Samsung plasma that has developed vertical white lines across the screen about 1 inch apart. Quality of picture is still great and unaffected. Lines have left once or twice but come back. Ca
Maybe it's time 4 a new t.v. Do you leave t.v. on a lot or play a lot games. Turn off your t.v. when not using. Is t.v. old, get a new new one. You will be you did. The newer sets have HD which make for better viewing. I suggest an LED and not a Plasma.
Jan 28, 2015 | Samsung PN50B450B1DXZA - 50in Ws Plasma Tv...
I my toshiba regza 40rf35ou vertical lines 1/2 of screen for about 12 minutes then great picture
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Vertical line problems to LCD screens are described with illustrations. Surf the site with patience.
Mar 20, 2014 | Toshiba 52HL167 52 in. LCD HDTV
White spots on sony bravia 32" S series
what is the cause for the televisions screen to get white spots that spread
Aug 05, 2013 | Sony BRAVIA Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Samsung LTN1535 15 in. HD-Ready LCD Television Logo
54,826 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
