Question about Generac Power Systems Generac 5522 14 Kw AirCooled Standby Generator
I purchased a new Generac 20 KW air cooled standby generator. It shuts down under its excercise program and lists a low voltage fault code. I can start the unit in the manual mode and it starts and runs just fine. Any ideas. The units is under warrenty but the closest authorized dealer is two hours away.
    Top Expert:
  • Generac Powe... Master
  • 53,745 Answers
Under warranty , you best have to wait the time as anything you do to fix it will void the warranty which will suit the service agent just fine
if you void the warranty he will get 2 hours travelling time plus the cost to repair time so don't touch it
Posted on Jan 05, 2018
SOURCE:
  • 5 Answers
SOURCE: generator 30
fuse are meant to protect the costlier part of the machine thereby damaging itself.  there is probably overloading of your circuit. call the electrician and find the actual power required by your house.  there is a possibility of having a short circuit in your generator. your local electrician can check it.
Posted on Jan 24, 2009
CarlGehrke
  • 169 Answers
SOURCE: 10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Posted on Apr 06, 2009
  • 26 Answers
SOURCE: Attempted to start Generac Guardian 15 kw air
I work on these every day. Its either gonna be the rotor or stater, the voltage regulator, but most likely its a bad stepper motor which is the throttle motor, or control board. Thats all that could be causing that so its one of those. If its the rotor or stater thats bad it causes the generator to RPM up because it thinks its not producing enough power due to that. I had the same problem with the same one we just fixed and it was the slip rings on the end of the rotor so bad rotor.
Posted on Jul 09, 2009
SOURCE: Generac Guardian 15 kw overspeed fault
Did you remember to set the overspeed shutdown threshold on the control board?
Posted on Jun 07, 2010
  • 10865 Answers
SOURCE: generator starts and runs for
Hi 'Phil. the biggest problem with generators is that they sit with fuel in the carburator for long periods of time. This always gums up the carburator. From the sounds of yours, you can start by adding carb. cleaner to your fuel but in the end you may have to replace or rebuild your carburator. Joe
Thanks for choosing Fixya!
Posted on Mar 19, 2011
Why does it crank and almost start on 1st try?
Generac Generator Troubleshooting - YouTube
? 1:39
https://www.youtube.com/watch?v=AKN2dc59cxY
Dec 20, 2013 - Uploaded by Appliance Princess
I want to learn about Generac generator troubleshooting. ... I have a 16 kW propane fueled standby air-cooled generator. ... I have a brand new generac 20K guardian Evolution and the first time my power went out my generac ...
Generac Power Systems - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Utilities
Rating: 1.3 - ‎26 votes
Hey, Generac, make a change and start making generators that work, don't cost .....Standby generators are not supposed to be used as a primary power source ... and three months ago, I spent $4,000 to have a Guardian generator installed at ...
Generac standby generator - Propane - wont start?? - DoItYourself ...
www.doityourself.com/.../487838-generac-standby-generator-propane-w...
Feb 4, 2013 - I have a Generac 4LM41A standby generator that I need help introubleshooting and repairing. It is about 12 years old and hasn't been used ...
141 GENERAC complaints and reviews @ P'ed Consumer
Dec 12, 2015 | Generac GUARDIAN Standby Generator 10 kW/9...
Error code - 2400...stopped-alarm- fuse problem, fuses checks good
I has this problem after performing Schedule A maintenance. Called Generac. They advise this a trip caused by removing the fuse before work to prevent engine start up, The fix is to turn unit in off position and then press ENTER key.
Mar 14, 2015 | Generac 20 Kw Air-Cooled Standby Generator
Hello i just started my 8 kw hole house generater ran greatput my electric water heater on 26 amp draw andsmoke came out exhaust vent shut it down ran again great turned only heater on again took amp
8 kW has a 35 amp breaker on the unit. A typical hot water is 4500 watts at 240 volts = 18.75 amps on each leg. If you are measuring 26 on one side and 19 on the other it should be ok. If it is shutting down you may have a fuel problem or you may need to adjust voltage if it's too low. Which model of 8 kW is it?
Sep 07, 2014 | Generac Guardian Series 8 kW Air-cooled...
Engine will turn over/crank but will not run
All internal combustion engines have the same requirements. They must have the correct air fuel mixture and source of ignition in order to run. Although I am unfamiliar with the system you have, the fact thst it will start without the air filter but won't with the air filter indicates that you either have a dirty air filter (you said yours was clean) or you have too much fuel entering the combustion chamber. Beyond that I would only be guessing the reason (air fuel mixture regulator, worn jet, wrong size jet, something else bocking air flow etc.)
Dec 26, 2012 | Generac Power Systems Generac 5525 20 Kw...
Under voltage alarm /shutdown on generac 10 kw gen.
The brushes on Generac automatic units are most likely not lined up with the slip rings and will wear down and burn out very fast. There is no way of checking this during assenbly because they are hidden from view and the generator has to be dismantled to be able to replace them. It's an extremely poor design and Genrac should face a class action lawsuit for producing this piece of junk.
Sep 18, 2012 | Generac 6051 Guardian Series Air-Cooled...
Generac Guardian 12 KW Model 04456-2 shuts down on overspeed in cold weather
Leigh,
See my 5/22/12 comments on my "overspeed fault" problem resolution [Generac 43903 standby Generator overspeed indicator on starting] . If it only runs for a few seconds and then quits, you may have a similar condition to the one my unit had. A good technician should be able to diagnose the problem and determine if you have a similar failure to the one I had, or one of the other causes suggested by RSG000.
Jan 20, 2012 | Generac 13,000 Watt / 13,000 Watt Home...
I have a Generac Guardian 20kw air cooled standby generator. I recently replaced the battery charger as the battery went dead a few times over the last several months. Upon replacing the charger, I now...
The battery could be bad. Try to measure the battery voltage when you try to start. If the battery is bad then the voltage will drop quite low when the battery is loaded with trying to start the set. If you can borrow a similar battery you could just try with it.
Oct 21, 2017 | Generac Guardian Model 5784 20 Kw...
Generac Model 5525-1 20kw air cooled standby generator Question: How do you access the battery? I think it is behind the front panel, but can't readily see how to open/remove the front panel. Thanks!
2 bolts on top of the front panel. Take them out and then just puul up and it come off. you can then easily remove the battery but make sure the leads dont touch as they still have charger power running through them.
Dec 04, 2010 | Generac Power Systems Generac 5525 20 Kw...
Apr 03, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Generac Power Systems Generac 5522 14 Kw AirCooled Standby Generator Logo
1,840 people viewed this question
Top Generac Power Systems Electrical Supplies Experts
John Trevino
scj103
STEVE
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
