More then likely, needle could be stuck closed. Fuel bowl should be easy to remove, make sure needle moves when float droppes, and fuel should flow. Remove fuel line from carb and make sure fuel is running out of tank, when fuel valve is runed on.
Add fuel preservitive, and heat to fuel every year, Use minimal amount of fuel, drain and recharge every year with fresh fuel with preservitive. Run Monthly, turn off fuel and let most of fuel to be used before turning off ignition.
