F27
OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for
more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump
runs constantly, even if PAUSE/CANCEL is pressed twice and
the display is cleared. Turn off hot and cold water faucets and
unplug the unit before servicing.
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure
switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
