If compressor starts, check the running current of the compressor. If amperage is too high together with the discharge pressure, try cleaning the condenser fins and then after cleaning test the amperage and pressure again. If the pressure is still above the normal operating of 300psi, release some freon. If the discharge is too low below 200psi and running ampere of compressor is below the rated ampere of the unit add some freon from the suction line until it reaches 60-65psi. If still suspicious with the unit, try removing all freon charge and evacuate the system to 30 in. Hg to remove any moisture from the system and hold the vacuum for 30 minutes. If no increase in system pressure, recharge and check pressures and amperage.
