Dometic RM2652 Refrigerator Logo
Posted on Aug 31, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a Dometic DM2862 fridge. Freezer on goes down to 12 deg. and lower unit down to 38 deg., but during day the temps are: freezer - 22 deg. and lower - 44 deg. Is this normal? Can I fix this?
Anonymous
Level 3:
  • Master 2,006 Answers
  • Posted on Sep 12, 2011
Anonymous
Master
Level 3:
Answers
2006
Questions
Helped
592612
Points
6261
While there is some fluctuations in temperature in Dometics from night and day, but it is usally the reverse of what you state. Warmer in the day time when the unit is opened more. I would check the temperature settings and if they are correct then check the thermostat.
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
1helpful
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
1helpful
Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
1helpful
Model#25360722000 is this a freezer or fridge? kenmore
What is it? A single door or a double door unit. If a single door, what temperature does it go down to? lower than 0 deg. c or +/- 3 to 5 deg. c In other words, lower than o it is a freezer. Above 1, it is a fridge..
Whirlpool ER8AHMXRQ01 fridge too cold
Adjust the setting until you can maintain a temp of 0 in the freezer and between 32 and 38 in the ref. These are the normal operating temps for this box.
Dometic fridge
I would look for a ventilation problem. If the fridge is working at that level nothing wrong with electric. The unit needs air to move up and out the top to make the freezer work. It sounds like the air is only moving the wrong way out the lower vent. Careful it could just be a birds nest but it may be a large wasp nest blocking the roof opening.
3helpful
3answers
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
Top Dometic Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Virgil Watts
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
