Question about Nortel Business Series Terminal T7208 - digital phone
My phone displays forward>0 and will not accept transfers from any other phone in the office apart from 0 how can I remove this
    New Friend:
On your nortel phone; press "feature # 4" and it will be cancelled.
Posted on Aug 29, 2012
SOURCE:
Transfer button and specific office intercom buttons no longer work.
It's tough to program on the old DK systems. If you have a newer CiX system:
>Leave phone on-hook
>Enter #9876 (Display: Programming)
>Press HOLD
>Press key to be programmed (only programmable keys on the right)
>Enter 610 plus the extension number
>Press the key to be programmed again (Display: Data Programmed)
Nov 23, 2015 | Toshiba DKT3020S Corded Phone
Tip
Sony Ericsson Secret Code
<span><br />IMEI number: * # 0 6 #<br /><br />Software version: &gt; * &lt; &lt; * &lt; *<br /><br />Default Language: &lt; 0 0 0 0 &gt;<br /><br />Enter to phone menu without SimCard - after Wrong PIN: press NO: * * 0 4 * 0 0 0 0 * 0 0 0 0 * 0 0 0 0 #<br /><br />Information about SIMLOCK: &lt; * * &lt;<br /><br />Sony Ericsson Secret Menu: -&gt; * &lt;- &lt;- * &lt;- *<br /><br />(-&gt; means press joystick, arrow keys or jogdial to the right and &lt;- means left.)<br /><br />You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels.<br /><br />You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests)<br /><br />IMEI Number: *#06#<br /><br />Lockstatus: &lt;- * * &lt;-<br /><br />Shortcut to last dialed numbers: 0#<br /><br />Shortcut to sim numbers: On main menu type a number and press #<br /><br />If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press &lt; 0000 &gt; . &lt; stands for left arrow button or joystick and &gt; stands for right arrow button or joystick.<br /><br />note! Try these codes at your own risk! We don't accept any complaints. Some of these codes may not work in your mobiles.</span>
on Jul 11, 2011 | Cell Phones
How to clear notification transfer roller needs to be replaced soon.
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 19, 2015 | Genuine Konica Minolta Konica Minolta...
How do I increase ring time before phone transfers to voicemail
Which phone are you using - please be specific.
Generally Go To Settings > Call Settings > Additional Settings / Call Forwarding Settings > Voice Calls > Change the always forward Settings, here it will ask you for Number of Rings Before Forwarding. Change that as per your convenience.
Sep 19, 2014 | Samsung Cell Phones
HOW DO I TRANSFER MY CALLS TO ANOTHER PHONE?
1. Find "Voice call"
2. Select divert type
3. Divert calls to alternative number
  • Key in the required number and tap Enable.
Aug 28, 2014 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
How di i transfer photos from one phone to another
Hi
Through Bluetooth perhaps?
[Source phone] >Open the picture >select send >via Bluetooth >Search device [turn Bluetooth on on the Samsung Galaxy] >accept the second phone on search results [Samsung Galaxy] >accept data [on Samsung Galaxy].
Feb 29, 2012 | Samsung Cell Phones
How we trasfer files from phone memory to memory card on E51
In Office use the File Mgr. facility.
1. In Menu, Select Office then Choose File Mgr.
2. Select the files you want to transfer -> Select Option on while the file is selected. Choose Move to folder.
3. Select Memory Card, and so on.
The rest is pretty straight forward just like you would do on a PC
Jul 14, 2010 | Nokia E51 Cellular Phone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Nortel Business Series Terminal T7208 - digital phone Logo
718 people viewed this question
Top Nortel Computers & Internet Experts
Vuk B
ray gallant
ray gallant
Robert Karst
Robert Karst
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
