Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Whirlpool Duet front load washing machine is showing a F/H code. The manual says to check the hoses for kink/leaks etc. we have done that and there arent any. The machine still shows F/H what would be the next step in correcting this problem?
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Aug 31, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1232808
Points
12714
Hi
Error code FH appears when No water is detected entering machine or Pressure switch trip is not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display. If there is no water entering the unit then make sure that the inlet valves are working fine. You may need to check the continuity at the inlet valves. If the valves are fine then check whether inlet water hoses as they might be plugged. Also check for inlet water screen at the valve. However, if the water is entering into the washer then the Drain pump might not be working. Also inspect the Pressure Switch hose whether it is in good condition and properly connected to Tub and Pressure switch. Also check hoses for leak and inspect the flow meter. Hope this helps...
Daniel
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
