Re: My camera is several years old. The flash stopped...
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Thanks for your input. I fear the flash is trashed and I have decided to send it in for repair.Thanks for your input. I fear the flash is trashed and I have decided to send it in for repair.
You can't post conmments that contain an email address.
Take out the batteries and clean contacts with alcohol and a Q-tip the long ones like a doctor uses are better. If the batteries are more
than two years old I would replace them. I take it that this camera
probably uses AA. Reg. Alkaline batteries would be alright just to
try it with if you get it working then I would put a set of lithium batteries in it as these last far longer.You can also buy rechargeable AA batteries. If it has a lithium L-Ion rechargeable battery pack and it
is several years old you may want to buy a new one for it. There is
several reasonable sellers on Ebay with the proper battery for your camera. If this don't solve your problem I would say the camera is done. In my experience these new cameras just don't last as long as the old manual film cameras.
Your camera is 20+ years old. They are electronic and most likely it is dead. Clean your battery contacts. If that does not do it... again it's a 20+ year old camera. The electronics go, just like a dead tablet or computer, a bad transistor will kill the camera. You can buy used Rebels for dirt cheap, under $50. But again, you are buying an old camera.
Hello, sounds like you have a faulty battery,if the battery is several years old it will lose the capacity to boot the camera and the dock is trying to charge a defective battery,if you get a new battery, charge it for at least 6 hours or more.Hope this solves your problem. Regards,Russell
I would not recommend you fix it yourself since several of the inside componentes are high voltage and dangerous. But, why wont the flash turn on? if the batteries are good, could it be the battery contacts on the battery door and inside the flash? If the batteries have ever corroded (even a little) then that would be the problem. Use a pencil eraser to shine up the contacts until they are bright and shiney clean. Do not use sand paper or anthing vabbrasive as that will cause the contacts to corrod more and the problem will be worse.
Ive got an eos Rebel think its just over 4 years old for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Unfortunately you will either need to replace the flash unit... or if you're unlucky the main PCB. I don't think you will be able to do anything without either of those parts.
I have made my living running a digital camera repair business for several years now, wish I had better news for you about your camera. If we can help with the repair let us know.
The most likely culprit is a several year old battery that is not accepting or holding a sufficient charge. Turning the camera on, and taking a non-flash photo may not tax the battery too much. However, when the flash is called for, the power demand may exceed the battery's ability to deliver enough juice. A new(er) battery is probably your best bet to resolve the problem.
Your battery is probabily uncharged or disconnected. Try taking the battery out and putting it back in. Then charge it (by plugging in the AC adapter) until the green activity light stops flashing. If this does not work, your battery is probabily dead. Did you short it out? Or perhaps it is old. Li-Ion batteries (the kind used in these machines) lose their ability to hold their charge in a few years - even if they're not in use! So, if your battery is 3 or more years old, try considering a new battery.
Hi. I have exactly the same problem after owning this "camera" for under two years. Happened aftrer only 16mths.I also bought another battery(which I willl take back for a refund). The only solution that has been offered to me came from the supplier who said to buy ANOTHER one. Nice for them!!!!
