1999 Ford Explorer Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My reverse is out what could be the problem? - 1999 Ford Explorer
zsudas
Level 2:
Scholar:
  • Expert 114 Answers
  • Posted on Aug 30, 2011
zsudas
Expert
Level 2:
Scholar:
Answers
114
Questions
0
Helped
42148
Points
367
Low transmission fluid can cause this. Check the fluid with the vehicle running in Park or Neutral. Make sure to block the wheels and use the emergency brake for safety.
If it is not transmission fluid you could have a transmission problem. They commonly do this but there doesn't seem to be a recall on it.
Check the transmission fluid before you do anything else.
I have a 2003 Mazda Tribute, what wire do I hook my reverse camera up to, all the wires that lead to my reverse light are all hot when car is on and not in reverse
NOT TRUE AT ALL
IF REVERSE LAMPS DO NOT GLOW.!
ARE THE REVERSE LAMPS DEAD, KEY ON = PRNDL REVERSE SELECTED?
IF METER NEG LEAD IS ON GROUND
AND METER PLUS LEAD (VOLTS) IS TOUCHING REVERSE LAMP PIN , KEY OFF NO HOT.
KEY ON, IN REVERSE YES HOT (12VDC =HOT)
AND THE 2 LAMPS MUST GLOW OR THE METER IS NOT CONNECTED CORRECTLY
START BY TESTING THAT REVERSE LAMPS DO INFACT WORK
AND NOT KEY OFF
AND NOT GLOW IN DRIVE AND PARK AND NEUTRAL.
How do i add transmission fluid? Why won't it stay in reverse gear?
VWVortex.com - 1997 MK3 Jetta 2.0L 8v 5spd Reverse Gear Problem ...
forums.vwvortex.com > ... > Golf III & Jetta III
Dec 8, 2006 - 25 posts - ‎18 authors Hello, I have a 1997 MK3 Jetta 2.0L 8v 5spd my reverse gear is ... car in reverse- always, not even a little rolling, i have found that vw trannys r .... Member MKIII_96'sAvatar .... misalignment and problems with the transmission staying in gear. .... You can ask a hundred ways, but it won't change the answer/s. Won't go into 5th gear.
Apr 17, 2009
1996 Jetta 2.0 5spd - No Reverse
Jan 5, 2009
Car won't go into REVERSE!!! WTF? Any ideas?
Nov 14, 2008
Transmission Shift Lever Stuck in Park - or, Key ...
Nov 13, 2005
More results from forums.vwvortex.com
Volkswagen Cabrio Questions - pops out of reverse ...
www.cargurus.com > Questions > Volkswagen > Cabrio
CarGurusMar 26, 2012 - My 96 Cabrio pops out of reverse then makes grinding noise. ... worse case is the reverse gear has a few teeth missing which is a common problem in 97 and older ... Won't stay in reverse 1 answer ... 1991 Volkswagen Passat.
We have a 2011 ford f350 and are trying to t/s the reverse lights. we checked the fuses. what else might it be. we cant find a diagram to the wiring.
In the BJB - battery junction box under the hood ,is a reversing lamp relay. Check it or try a known good one !an check fuse F70 10amp in the BJB .
Reversing Lamps
The reversing lamp system consists of the following components:
  • Rear lamps
  • Reversing lamp switch
  • PCM
  • BCM
When the transmission is placed in REVERSE (R), the BCM provides voltage to the reversing lamps. The reversing lamps are located within the rear lamp assemblies.
When the transmission is in REVERSE, the PCM (gasoline engine) or the Transmission Control Module (TCM) (diesel engine) sends a message over the High Speed Controller Area Network (HS-CAN) to the Body Control Module (BCM) indicating the transmission is in REVERSE. The BCM provides voltage to the reversing lamps when it receives the message that the transmission is in REVERSE and the ignition is in the RUN state. You could have a transmission range sensor problem , check to see if it is adjusted correctly ! Need to have a scan tool to make sure the BCM is receiving signal from the PCM . This is complex for someone who doesn't deal with or know about serial data communications ! All it is ,is electric inputs to a control module, then the control module configures it into data bits an bytes 1's an 0's then sends it out on the Data bus. The module that needs this info reads it an turns on the lights.This system can set codes in the bcm ,leading to a problem.
  • DTC B1277:11 (Reverse Lamp: Circuit Short To Ground) - a DTC that sets when the BCMdetects a short to ground from the reversing lamp output circuit.
  • DTC B1277:15 (Reverse Lamp: Circuit Short To Battery or Open) - a DTC that sets when the BCMdetects an open from the reversing lamp output circuit.
  • Could set codes in the PCM - powertrain control module for a transmission range sensor problem !
  • 0helpful
    The reverse gear is fine it's the reversing lights that go out when it goes in to reverse gear
    You say that the reverse lights go out when reverse gear is selected! At what point are they on? Before reverse is selected?
    95 dodge neon wont go into reverse
    Reverse clutch pack problem .
    1helpful
    Have a 94 New Yorker when I put it in reverse I get a red R on the PRNDL and don't have reverse all other gears are green and work. What might be causing this?
    the reverse clutch in the trans is after failing.there are two clutch packs in trans for reverse,low/reverse and reverse clutch in overdrive unit,so where you have all foward gears the low/ reverse is ok the reverse clutch in od unit is most likely culpret
    5helpful
    2005 Pathfinder no reverse lights
    On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced
    4helpful
    NO REVERSE LIGHTS REAR PARK SENSOR WHEN REVERSE SELECTED
    On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced. The switch is just plug and play
    Top Ford Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Thomas Perkins
    Thomas Perkins
    Are you a Ford Expert? Answer questions, earn points and help others
