SOURCE: I cant adjust the minite hand backwards if the watch is gaining
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again.
One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait.
By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely.
Do not forget to rate, please.
SOURCE: I have fitted a new
I think it required cleaning for movement any expert watch maker will do it ,,, and if you are in chicago we can clean it.
From
Amfix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph : 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Testimonial: "Thanks for your advice . I stay in the Uk . The rubber seal has perished inside the watch which I think may be the problem ."
