First thing check the carbon brushes, when they wear out they arc at the armature. Two black screw covers one either side of the top motor housing. The brushes are keyed to only go back in one way so make a note of which corner of the brush has been shaved off. If you look in the hole with a torch you can see the little blocker in one corner deep down. As a rule it's back top corner on one side and back bottom corner on the other side.
SOURCE: Mixer works at high speed only
You might have someone repair it for you; here is a place that charges a flat fee of $69.95 and thats including the return shipping. Check 'em out:http://www.marbeck.com/repair_mixer_kitchenaid.html The speed controller board sounds like the right direction but it hard to know if that is the issue until you install a new part. This is a known issue as far as I have heard around the internet. You might give KA a call and see if they can help; all they can say is no. I have heard they revised the part to fix the problem; my brother had a couple of boards replaced on his pro model and now it seems fine. Good luck!
SOURCE: KA mixer repair manual download
Here's where you can find parts diagrams
http://www.goodmans.net/get_dept_933.htm
and here's where you can find a service manual
http://www.mendingshed.com/kitaidparts.html
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. [email protected]. Let me know if it works.
SOURCE: My K5A 300watt Kitchenaid mixer only goes one
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
Adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
SOURCE: My Kitchenaid K45 mixer only runs at high speed.
I just fixed my 8 yo mixer! Would only work at highest speeds... first took it apart because it was making a terrible noise. Tthrough this site I figured out how to take it apart and replace the grease. Gears were in good shape, but a small nut fell out of the back while I was working on it. Finished putting it back together, found the spot where the nut belonged- holding the metal housing of the motor to the head. I turned it on and all I could get were the two highest speeds so I took the back panel off again and played with the bottom screw- it seems to adjust something on the wire that controls the speed. So take a philips screwdriver and adjust that screw and see if you get all the speeds back.
