ASUS P4P800-MX Motherboard Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motherboard P4P800-MX... I need to know exactly where I should conect the LEDs... I need the manual for this motherboard. thanks
Anonymous
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Aug 30, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
12274
Points
184
Here is a link to your manual directly from the ASUS website
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=15&m=P4P800-MX&os=&hashedid=HzMhkEvUD25yNtOo
once on that page select OS -> Other then select manuals and you will see all the manuals for your board.
Azrael SRL
Level 3:
  • ASUS Master 11,800 Answers
Azrael SRL
ASUS Master
Level 3:
Answers
11800
Questions
0
Helped
2566919
Points
35672
Http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-mx/e1880_p4p800-mx.pdf
J ai beaucoup de probleme avec mon desktop p4p800-mx chassis intruded
You have a problem with the Chassis Intrusion part, of the Asus P4P800-MX motherboard?
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800MX/#download
The Chassis Intrusion header is below the CMOS battery to the left.
It is in-between the two black SATA connectors.
It is a 4-pin header.
From -> LEFT to RIGHT pins are numbered 1, 2, 3, and 4.
Put a Jumper Cap on Pins 3 and 4, and bypass the Chassis Intrusion option.
In the -> OS box, click on the blue Down Arrow. Now click on Windows XP.
In the drop down list, click on the + sign to the left of Manual (5)
Version E1880 - P4P800-MX user's manual (English version) E1880
Click on the blue -> Global
Go to Page 35. (PDF file page. Manual page is 1-25)
Chassis intrusion connector (4-1 pin Chassis1)
For additional questions please post in a Comment.
Regards,
joecoolvette
2answers
Man
If you are looking for the device drivers for your ASUS motherboard then -
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Lately, My computer will automatic turn it off after less than 10 min. I did change the fan already, but it still happen . My computer use Motherboard P4P800-MX. You think Should I need to replace the...
Is the fan working properly? And does the computer get too hot? If that is the case, you may want to change thermal paste on heat sinks or let somebody else do it.
The problem may be elsewhere than motherboard, for example the power supply unit could be faulty.
However, these boards go for like $50 on ebay.
I NEED P4P800-MX AUDIO DRIVER. NOT GETTING ON NET
Here's the Asus site for finding and downloading drivers and software:
You need to enter your product info: Procuck = motherboard Series = Socket 478 model = p4p800-mx
At this point a popup window will come up and ask you what operating system are you using, enter it from the list and continue (note that this list only goes up to windows xp). At this point you will be giving the list of all the drivers for your motherboard. search for the audio driver, download and install!!
Hope this helps!!
I have an Asus P4P800MX/S motherboard I got on Ebay. It came with no manual. The front panel connector is a 10 pin connection on the motherboard but the manuals I got from Asus state they are all a 20 pin...
https://www.manualslib.com/manual/444313/Asus-P4p800-Mx.html?page=38#manual
Page 38 is the front panel 20 pin connectors; if you have a 10 pin, you don't have that model. I would search the manual I linked to for the motherboard picture so you can determine what the 10 pin really is.
1helpful
I need a drivers for sound and intergrated graphic card on Asus p4p800 mx motherboard. I can not find it anywhere. Can you help me? Thanks
Hello the driver can be downloaded here:
Select the operating system and the driver you want
and click on global for download
The driver must be unziped before you can install it.
Good luck
I need to figure out the maximum RAM my motherboard will handle
You can download the required manual from:
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-021718.htm
According to the manual (page no:9), this board is designed to support up to 2 GB RAM.
Hope this answers your query. Thanks for using FixYa.
1helpful
I need to find out how much RAM my computer will handle but I do not have a users manual. I have a P4P800-MX motherboard. How can I find this out?
Your computer motherboard supports maximum 4 GB DDR400/333/266 non-ECC DDR SDRAM memory.
For more details and specifications, click here
9helpful
5answers
2answers
NO USB WORKING
Hi there what OS do you have loaded?
Im assuming you have XP loaded.....
have you tried to unistall and reinstall the USB ports?
reboot and restart,
should auto recognise the device and self install,
reboot and restart,Test usb
dont for get SP2 updates for functionality of the devices
Let me know the outcome thanks
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
