eMachines E19T5W 19" Monitor Logo
Posted on Aug 30, 2011
I have a E19T5W TFT LCD monitor, I've had it for 3 or maybe 4 years now... when I turn on the monitor it makes a high pitched whining sound, when the whining stops the screen goes black... sometimes when I turn on the monitor it doesn't make the whining sound and thus stays on for about 2 secs and then goes black... some days it can stay on for hours with no problems and other days it just won't do anything other than go right to the black screen when turned on... I have tried turning it on and off and on again and it just goes to the black screen... FWIW, the comp tower is an eMachines T3092, it's prob 6 years old, not sure if that helps or not... is there some solution I could try that would fix the problem, or will I just have to junk the monitor and get a new one?!?
2 Related Answers
Anonymous
  • 342 Answers
  • Posted on Jun 12, 2010
SOURCE: My eMachines E19T6W HD monitor started continually
I think this is due to the panel of your moniter this can be fixedby giving this mobile for service
bronk50
Brian Sullivan
  • 27725 Answers
  • Posted on Sep 30, 2011
SOURCE: Problems with my emachines monitor. I have an
youmight remove your graphics and check the socket for dust restart your computer this should activate the found new hardware wizard
if you run an extended desktop this will tell you if the monitor has gone bad
use a vga lead to attach it
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
i have read some reviews on your monitor
So the ex-hubby calls me with his woes - his eMachines T3124 is having problems. Seems that when he cold boots in the morning it hits the "E" splash screen and then just goes to black screen. No bios boot screen, no boot to windows. Everything sounds ok though. After a few restarts it boots ok. So, first trouble shoot is to replace the 180w Bestec power supply with a salvaged 300w Hippro from my T6420 (which was replaced with a 500w) - the one I replaced the mobo on. Works great ... for one night. Next morning I get the frantic call - now he gets nothing after the "E" splash but white wavy lines, but the computer sounds like it's running fine. Ok - ok ... think, think. First thought was maybe the onboard graphics have gone, next thought maybe the mobo is going ....
What is the next thing we do after trying a known, good power supply? Try another working montior. I had him try using a trusty older CRT monitor and Wha-Lah! After less than 3 years the E17T4 LCD monitor had failed. Most recent crisis handled. This little incident has made him realize though that he needs to burn all his picture and videos to CD. Scared him to think he could have lost them. Today's reminder? BURN your pictures and videos now! You never known when something might happen. And eMachines monitors are ****.
hope this helps
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
1helpful
Tv dead. high-pitched whine when plugged-in.
Sounds like the back-light inverter board has damaged. Check it.
Buzzing/whining noise while on charge.
This sounds like a cooling fan issue, inspect that....Clean the unit while you're in there, heat kills.
Sometimes goes ''clunk'' when coming to a stop,then makes noise like a chain being dragged over a pipe in 1st gear.Noise stops after a few minutes.Has a low pitched whine in OD,sometimes accompanied by a...
Maybe a stretched transfer case chain.
I wouldn't rule out some trans issues
Got the correct fluid in transfer or proper level
The clunk sounds like ,U-joints
Check all the mounts on everything,trans, transfer.etc
2answers
2answers
My new Acer P191W LCD Monitor has a high pitched whine that is extra loud on pages with rich and dark colors.
The PSU "power supply unit is taken on a lot of noise from the outlet. Can you tell us if you have it streight plugged into to a 120V AC outlet or is it plugged into a strip? The Solution for both is NEW strip i recommend APC or plug it into a strip and check the outlet and make sure its properly grounded this should shore up this problem or the unit itself is going out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2answers
E19t5w screen problem
Hi...there,
Well, there are 2 things that caused thing problems... You've got a busted panel or you need to replaced a new AD Board.
2answers
Annoying high pitch noise coming from devise
I believe that this has involves the processor, and maybe the refresh rate (or the T E2's equivalent) being faster than the screen would like.
Sorry for the personification there (I want to sound smart.)
Acer al1916b high pitched noise when on standby.
Sounds like you could have an open ground? Also might check the wiring to see if you have a faulty connection in VGA cable or power supply cable
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
