Archos 604 WiFi Digital Media Player Logo
Posted on Sep 10, 2008
Archos Recovery (code 2)
I have the Archos 504 and it is coming up with Recovery ( code 2 ). I have tried all 3 options of format disk, repair and No recovery but it just keeps going back to the same screen, have tried resetting it but still does same thing, PLEASE HELP. My Archos 604 WIFI has the same problem. I've reviewed in the forum and the only suggestion I found was to review the hard disk connection, I've opened the Archos and I can confirm that it's correct. At present the problem persists and I don't know what to do. Please, any help?
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 03, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
1499
Points
14
Send them back to Archos if they are still under warranty. If not, you're out of luck because they'll charge you about US$140 to repair the hard drive + postage.
Recovery code 2 / system is damaged. would you like to recover it ? No Repair Format Disk Any body have any ideas ?
hey, did you sort this out? If so, how?cause I have the exact same problem...If I manage to be fast enough to press the button to "recover" or "format" before the screen freezes then it just goes into recovery for ages but accomplishes nothing. My computer doesn't recognize my archos so oI can't upload anything or update anything.?????
3helpful
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
I have archos 504 160 gb when it turn on i have message (recovery code 4) would you like to recover your system ? no - repair disk - format disk when i push no no thing action . when push repair or...
This is a recovery mode, and this menu allows you to:
-Format your hard drive
-Restore your system
In case of repair disk is selected :
For the first step you have to go on our website, and download the latest firmware update for your product.
Plug your Archos 504/604 on the computer and copy the firmware previously downloaded at the root of your device.
Disconnect your device as usual, and select done on the screen.
You have to plug the dc adaptor to update successfully, press a button to reboot your device.here is the web address  http://www.archos.com/support/support_tech/updates.html?country=us&lang=en&#firm
1helpful
My archos 504 will play for 2-3 mins then will freeze.
you have to format your hd. for this conect your dvd player to pc. there is coming your hdd with a letter disk . click with the right button mouse and give format. after formating make sure to put some video from media player as described in your manual. (videos must be codec compatible to play). if is repeated same thing check your audi and video setting if nothing.... good luck i dont know another solution.
3helpful
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
5helpful
2answers
Can't get out of recovery code 2 on archos 504
I had the same problem and manage to solve it. You need to do the following
a. go to Archos website and download latest firmware and save on your pc
b. turn on 504 and select repair - unit not connected to pcm you will see a screen where you wil be prompted to press DONE (but DONT press it yet!!!!)
c. connect 504 to pc and wait until pc recognise it (it will recognize it this time)
d. copy firmware from pc and paste it to 504 root directory.
e. press done on 504. now when the device restarts you just select Repair and that should work. :)
Recovery (code 2)
I got the same message when I took out the hard drive. I'm sure this will void any warrant, but maybe you should open it up and make sure the hard drive ribbon is secure.
6helpful
8answers
Recovery code 4 on archos 504
d. copy firmware from pc and past to 504 root directory.
e. press done on 504. that should work. I've spent the best part of 10 hours looking for a solution to the dreaded recovery code 4. The problem is a corrupt os. I hope you're as lucky as me.
I still have a problem with mine though...a screen that blink constantly.
2answers
Recovery (code 2)
open the battery pack, and push the hard drive back into it's slot.
it has prongs that attach, tat was always my problem.
sorry if it no help to some.
2answers
Help me pleaseeee
sent it back to archos with your receipt if less than 1 year and talk to customer service
there is nothingg you can do about it
been there done that.
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
