Sylvania LD320SSX LCD TV Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sylvania LD320SSX 32-Inch 720p LCD HDTV/DVD Combo fails to turn on(power light flashes green, turns solid green 10-15 minutes then red). Leading up to this condition it would take several attempts to turn unit on from remote or power button. Inspected circuit boards, and there are no bulging capacitors. Tried a reset using the remote's "hidden" buttons.
Sol Gerena
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 11, 2013
Sol Gerena
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1120
Points
I dont have the remote n i want to reset it how can i do that
Daniel
Level 2:
Sergeant:
  • Expert 299 Answers
  • Posted on Aug 30, 2011
Daniel
Expert
Level 2:
Sergeant:
Answers
299
Questions
0
Helped
63183
Points
855
You checked for bad capacitors, but did you check for bad soldier joints?
I would start there. Also, be prepared to replace the Power Supply Board.
  • Anonymous Jan 26, 2012
    call the number on the back of the tv. because there is a product recall for this specific reason. i did and they repaired it for free w/paid shipping. no out of pocket expense at all.
  • Anonymous Jun 24, 2012
    Is there a schematic for the LD320SSX power supply board?
Screen only flashes colors, no controls function
remove power from the set and any box being used with it, after a while power both back up, a box or the set can cause this issue.
TURNS ON THEN FLASHES GREEN FOR ABOUT A MINUTE THEN KEEPS FLASHING RED .WHATS WRONG?
Probable lamp failure, lamp won't turn on leading to red light to come on. How many times does it flash? 3 means safety switch bad, 5 flashes means lamp or lamp ballast failing.
Need code for dish network remote for Sylvania LD320SSX
hi! i have here a couple of codes for your sylvania TV, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483. this is for sylvania HDTV 1046, 1465. this is for the tv/dvd combo 1150, 2092, 1464, 2408, 1465, 2260. this is for the TV/DVD/VCR combo 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147. this is for the TV/VCR combo 1145, 3095. hope this helps!!!! goodluck!!!
1helpful
2answers
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Insignia? 37 720p Flat Panel LCD HDTV will not
Power-cycle the unit (turn it off and unplug for several minutes). If you're unable to power the unit on successfully, the TV probably requires repairs. In home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
2answers
I have the Direct TV RC64 remote and the Sylvania TV/DVD Combo Model LD320SSX. Is there any way I can program this to control the volume and power for the TV?
You can program the Direct TV remote to control your TV by using the below steps:
1. Turn on the TV
2. Slide the MODE switch to the TV position.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
4. Using the number keys enter the 5-digit code (20675, 21268). If performed correctly, the green light under TV flashed twice.
5.Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying the other code.
6. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
For further details and programming procedures and codes, you can download the complete user manual for your remote by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
