Panasonic KX-T7730 Corded Phone Logo
Posted on Aug 30, 2011
Hi I am working at the Switchboard. I have a Panasonic KX-T7730 that is seven years old. Every office has an extension code and a name. I want to change the display names of the extensions as it still shows the names of people that worked here 7 years ago. Hope you can help me. Thanx
Shawn Glass
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Oct 02, 2011
Shawn Glass
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
6895
Points
20
This has to be done on Ext 101, or whichever phone is the programming phone. Press program *#1234. Then enter in 004. Press Speakerphone. It should be asking for a jack number. You can press speakerphone again to go to the first ext. Spell out the name using the keypad (2 is A, B and C and so on). When done press the autodial/store button. Then you can press speakerphone to go to the next phone. To get out of programming just pick up and hang up your phone or press the program button.
Hi I have panasonic kx-t7730 and I have a problem. We have two lines but only rings on switchboard. We also Use cordless panasonic phone but it does not ring unles i transfer to it. I have already done...
In a TA series, the ringing is programmed in system programs 408-410. You go to the main phone, enter system programming, and select those options and turn on ringing per line and per extension.
Carl
4helpful
How do I change the extention names on KX-T7730?
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ).
3. Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change.
4. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered.
5. Press PROGRAM to exit program mode and you are done.
1helpful
How do i find out what extension i am on?
If you have a KX-T7730 phone press the * button until it shows your extension number. If not, phone the switchboard operator (usually 10, 101 or 9) and ask the person what the number on the display is.
If this was helpfull please vote
Thanke you
Names
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
PLEASE rate / vote this answer if it was helpful.
Thank you.
2helpful
Cant Change the display name
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
KX-Txx 308/824 system:
SHORT WAY:
From the Switcboard / Main telephone
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
6helpful
How do you program a Panasonic KX-T7730?
I assume that you want to program the extension names.
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system. From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the hook/cradle press PROGRAM * # followed by the system password ( default is 1234). Now press 604 and then SP-PHONE. Enter the jack number you wish to change ( 01 is extension 101, 02 is extension 102 etc. ). Enter the name ( basically the same as texting on a cellphone ). Press AUTO DIAL / STORE to save your change. To go to the next extension press SP-PHONE. Don’t forget to press AUTO DIAL / STORE to save your change after each name entered. Press PROGRAM to exit program mode and you are done.
Thank you.
2helpful
The incorrect name being displayed when you use a preset number
The side buttons is programmed as extensions
To change the extension names follow these steps :
2helpful
Panasonic Adv Hybride System KX-T7730
Thank you.
2helpful
For assigning a person name to the extention
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
