Bosch 24 in. SHU6802UC / SHU6806UC Built-in Dishwasher Logo
River May Posted on Apr 01, 2006
Bosch My bosch dishwasher shows an "F" on the display when started. It sounds louder than usual but the cycle doesn't start. I made sure there were no obstructions, debris, etc but no help. Thanks.
  • Anonymous Sep 06, 2008
    The screen shows an F and will not run
  • Anonymous Apr 28, 2009
    Pressed both buttons at the same time, now CL shows in the panel
Anonymous
Level 1:
  • Contributor 21 Answers
  • Posted on Jul 25, 2009
Anonymous
Contributor
Level 1:
Answers
21
Questions
Helped
21179
Points
48
F is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5397
Points
Hi
Bosch diswasher indicaates "F". I've taken off Aquastop, checked water flow (good), cleaned little filter (it was clean) and reconnected as per instructions in manual. Still no go. I understand that it means "filling" fault. Where else can I check?
Anonymous
Level 1:
Problem Solver:
  • Contributor 27 Answers
  • Posted on Apr 02, 2006
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
27
Questions
0
Helped
10799
Points
32
Basically ?F? means ? filling fault so something is wrong the water level, if you want to try fixing it yourself you need to do a test on your dishwasher machine. To start testing, press both ?SCRUB WASH? and ?DELICATE/ECONO? buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g.?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor ("Sensotronic") fault 4 = Filling fault F = Filling fault (display occurs during wash, not test). To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code "4" and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), display will show "0", water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code "8" immediately and testing will end shortly after water has started circulating. Good luck
What did h01error code mean ? Answer me plz
Is yours a Bosch machine? On Bosch the H01 usually means you have turned on the Delayed Start feature on the machine. H01 means the wash cycle won't start for one hour, H02 means it won't start for two hours.
Try this website to see how to turn it off.
Aug 11, 2021 • Dishwashers
Bosch SHE3AR52UC won't start. I keep pushing the start button, it starts then stops within 4- seconds
If dishwasher won't drain it will not start to fill most of Bosch unit will display error message it's eill flash some light or will show y you on the display
Bosch dishwasher error 24
Hi!
here are manuals to BOSCH dishwashers. Please kindly check if there is a manual to your device which helps you to solve the problem. https://manualsbrain.com/en/brands/bosch/dishwashers
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
2helpful
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
1helpful
2answers
What is error code 2H
My Bosch dishwasher did the same thing. When the wash cycle starts, the dishwasher fills with water and then the heater is supposed to turn on to heat the water. If the water does not heat, then it will display 2H continuously. The heating element may be bad, but a more likely cause is with the control module. Bosch has a problem with the control module printed circuit (pc) board that powers the heater on many models. The solution requires some technical expertise and soldering skills. The details are explained in the document "Bosch dishwasher troubleshooting tips" on page 11. Download here
Bosch recommends re-soldering the connection, which is a temporary fix. The problem is that the copper conductor (called a trace) on the circuit board is not wide enough to handle the current required for the heating element, and as a result the copper trace overheats, causing the solder to melt on the relay connection. The best solution is to remove the control module PC board and solder a short length of copper wire between the pins to prevent the overheating problem, as shown in the attached photo (magnified portion of PC board). I did this on my dishwasher and it has been trouble-free for over 3 years.
2answers
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
2helpful
Is there a way to turn off the cycle completion signal. I have a Bosch SHY66C02UC/14
OK, I think I have figured this out. Let me first give this important piece of information. The control panel for my dishwasher was replaced recently. That's why I now have to deal with this issue. I have a Bosch SHY66C model. As I stated in a previous post, the user manual I found on the web has identical structions for changing the amount of rinse aid dispensed and for changing the volume on the cycle completion beeper (or for disabling it). Following the instructions fixed the former.
Here is what I did
1) With dishwasher off, I pressed and held the "Delay Start Hours" button
2) I pressed the on/off button. The beeper begin to sound.
3) I released both buttons (not sure this step is necessary)
4) I repeatedly pressed the "Delay Start Hours" button until the signal turned off
(LED display showed 0)
5) I pressed the on/off button (not sure this still is necessary)
That seems to have fixed the problem. So, I don't know if the user manual is wrong or my control panel was replaced with one from a different model (such as the SHU9950 where I found these instructions).
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
