This is
almost certainly a simple problem with your empty pump filter being clogged.
The empty cycle is timed and if it can't get all the water out in time because
the filter is blocked and slowing the empty down, then it will fail safe and
won't step on to the final spin cycle with excess water in the drum. While it's
trying to get the water evacuated, you will probably see the machine doing a
slow tumble for up to 8 minutes and you may also hear the empty pump running
too.
You need to
locate and clean the filter. Depending on the model (You haven
