Dishwashers Logo
Posted on Aug 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishes and glasses are stained. Silverware is spotty, I've checked water pressure and temperature and they are within spec. Soap dispenser and jet-dry compartments are filled as per owner's manual. Have rinsed dishes and silver in vinegar and rewashed in small loads. This helps but the spots and stains come back after a few washings. Any suggestions ??
Mike
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 677 Answers
  • Posted on Sep 06, 2011
Mike
Expert
Level 2:
Prodigy:
Answers
677
Questions
0
Helped
366424
Points
782
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Gere knutson
Level 3:
  • KitchenAid Master 842 Answers
  • Posted on Aug 30, 2011
Gere knutson
KitchenAid Master
Level 3:
Answers
842
Questions
Helped
218485
Points
2087
Add glass Magic or Lemon Shine to the soap in the door for every load, this will impress you. You will not have to rewash again. It only takes 2 tablespoon on top of the soap in the door.
I find Lemon Shine at Target, under four dollars and works great.
You have nothing to loose.....
You can smile again..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Dishes do not clean, although the water is hot and the soap dispenses. Dishes and glasses have a cloudy residue at times, and dishes sometimes have small food particles baked onto the surfaces.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
This is a 3 yr old dishwasher with very gentle use. It now is not cleaning glasses....even when rinsed before hand the glasses are still stained and spotted. Also my silverware needs to be completely...
Hard water stains are easily taken care of with the help of vinegar. Add 1/4 vinegar to the cycle when you start it and it will help to remove spots and cloudiness.
As for food residue you might check your filters and water pressure.
2helpful
We get a white film on dishes and silverware after running then dishwasher. It 's getting worse gradually over time. What is the cause and how do we correct it.
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Film on my dishes and silverware
the detergent is not breaking down,it could be hard water try cleaning the soap dispenser,also try vinegar or CLR and run with no dishes.clean out sprayer arms make sure the wholes are not blocked up,and before loading machine rinse off dishes before loading.
1helpful
White film on all dishes and silverware
1helpful
4answers
CLOUDY DISHES IN DISHWASHER SOMETIMES THE DISHES COME OUT CLOUDY
modern day dishwasher use less water than the older ones so you have to use less soap a lot less only 2 tablespoons but you also have to use rinse aid with the very little soap the cloudy residue on the dishes is left over soap
4helpful
The dishes do not get clean. Food is left on plates, in bowls, on silverware. Coffee stains are building in cups. Milk leaves a "film" on glasses. When the cycle is finished, it appears that the water...
Hi, it sounds like your dishwasher is plugged up with soap deposits, and/or Calcium deposits.
In an empty dishwasher, put 2 cereal/soup bowls full of vinegar on bottom shelf, and run your dishwasher.
This should clean out all the deposits.
I do this about once every six weeks as our water is very hard.
Fred
Sep 30, 2009 • Dishwashers
2helpful
Dishes, glasses & silverware have white film, look unclean!
2helpful
GE profile PDW7880J Soap left on dishes and soap left in dispenser
Dishwasher - Soap Stuck in Cup If you have dishwasher detergent stuck in the soap cup after a full cycle, please check for the following conditions:
  • The water temperature should be at 120 degrees (140 degrees if your dishwasher has water heating capability). Check your water temperature Check your water temperature.
  • Make sure the soap cup is not blocked by anything.
  • Allow the dishwasher to fill and make sure it is getting a proper amount of water. The dishwasher should fill for about 90 seconds. On permatuf models, the water should measure 3/8" above the island near the center of the tub. On all other models, the water should measure about 1/2" below the heating element.
  • Check the lower spray arm for any blockage in spray holes or items that would restrict its turning.
  • Make sure the soap cup has opened at the end of the cycle.
  • Check the sump area inside the dishwasher for any restrictions.
2answers
Soap left in dispenser. dried soap on dishes and siverware
After the fill cycle, check to make sure you have enough water in the dishwasher to wash effectively. You may need to have your fill valve replaced. You can test this by adding perhaps a liter of water to see if it makes a difference
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
