SOURCE: 42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
SOURCE: Screen goes black after couple seconds on my Polaroid 42" LCD
I had a TLX-4240B 42" Polaroid LCD TV and the screen would go black after about 10 minutes. There was still sound. I removed the two covers exposing the circuit boards behind the TV. I powered up the TV and waited for the screen to go black (I was going to start trying to pinpoint where the issue was with my trusting meter) then noticed a red light would come on when the screen would go black. there were 4 mini switches right above the red light. I switched the one that said burn and the TV has been working great since. good luck and let me know!
SOURCE: polaroid tv screen goes black after 30 40 minutes,
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
