There are 2 clips between the top and body of your washer that holds the top down. They are around 3 to 4 inches in from the sides along the front edge. You can use a putty knife to depress the clips while pulling up on the top and it should lift up. Use a flashlight to look in the crack and you can see the clips if that helps. There is a new style suspension kit for these washers that will help with the out of balance condition. Hope that helps.
