2006 Pontiac Solstice Logo
Posted on Aug 29, 2011
Change the water pump - 2006 Pontiac Solstice
Dan Fridenberg
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on Aug 29, 2011
Dan Fridenberg
Contributor
Level 1:
New Friend:
Answers
15
Questions
Helped
12148
Points
41
  • Tools Required
  • J 43651 Water Pump Holding Tool
  • Remove the thermostat housing.
  • Remove the water pump access plate from the front cover.
  • Remove the right hand fender liner.
    1. Important: A drain plug has been provided at the bottom of the water pump assembly for additional coolant drainage from the engine block and water pump.
    Drain the coolant from the water pump using the plug at the bottom of the pump.
    1. mportant: The water pump holding tool supports the sprocket and chain during water pump service. The tool must be used or the balance shaft must be re-timed.
    Install the J 43651 into position.
    1. Tighten the bolts on the water pump holding tool into the threads on the water pump sprocket.
    2. Install the access cover bolts that were removed earlier to secure the water pump holding tool to the front cover assembly.
    3. Remove the 3 inner water pump sprocket to water pump blots.
      1. Important: Be sure to remove both water pump bolts from the front of the engine block.
      Remove the 2 water pump bolts.
      Remove the rear 2 water pump bolts.
      1. Remove the water pump.
      2. Remove and discard the water pump O-ring seal.
      Installation Procedure
      1. Important: Prior to installing the water pump, read the entire procedure. This will help avoid balance shaft chain re-timing and ensure proper sealing.
      Install a NEW water pump O-ring seal.
      1. Important: A guide pin can be created to aid in water pump alignment. Use a M 6 m x 6 mm stud. Thread the pin into the water pump sprocket.
      Using the guide pin, align the pin with the water pump holding tool.
      1. Position the water pump against the engine block and hand tighten the water pump bolts.
      2. Notice: Refer to Fastener Notice.
      Install the inner water pump sprocket bolts. After 2 are snug, remove the guide pin and install the 3rd bolt.
      Tighten the bolts to 25 Nm (18 ft. lbs.).
      1. Tighten the water pump sprocket bolts last. Tighten the bolts to 10 Nm (89 inch lbs.).
      2. Remove the J 43651.
      3. Install the water pump access plate and bolts. Tighten the bolts to 10 Nm (89 inch lbs.).
      4. Install the right hand fender liner.
      5. Install the thermostat housing.
Where is water pump fuse located
If your water pump has failed you will simply just have to change it.It does not have a fuse and a rule of thumb is change the water pump when you change the timing belt at 60000 which is the correct interval to change the timing belt and you already have easy access to change the water pump also.
I would like instructions on changing a water pump in 2005 Chevy uplander V6 3900
This is probably the easiest water pump of all vehicles to change.
Water Pump Replacement
Removal Procedure
  1. Drain the cooling system.
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  1. Remove the water pump bolts, pump, and gasket.
  2. Clean the water pump mating surfaces.
  1. Install the water pump gasket and pump (1).
Notice: Refer to Fastener Notice in Service Precautions.
  1. Install the water pump bolts.
    • Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolt until snug.
  2. Install the drive belt
  3. Install the water pump pulley bolts.
    • Tighten the bolts to 25 Nm (18 ft. lbs.) .
  1. Fill the cooling system
  2. Inspect for leaks.
2000 FORD EXPEDITION OVERHEATING....changed thermostat,radiator cap, confirmed fan clutch is working, no radiator leak noted, changing coolant temperature sensor as a type...water pump not leaking or...
yes. the impellor on these engines have a tendency to come off the water pump.First you can see if the pump is working by removing a heater hose then have someone to start the engine. if the water sprays a good, solid stream out then the water pump is good. if the water just barely comes out or not at all then the pump is weak or "bad".
I have a 2003 pontiac grandam with a intake gasket leak. I am planning to have it fixed but i have advised to change the water pump also. I am having no water pump problems is that advisable to do.
CHANGE WATER PUMP WILL SAVE YOU SOME MONEY, TO CHANGE INTAKE GASKET HAVE TO DISAMBLE PART OF YOUR ENGINE , AND IF YOU NEVER HAVE CHANGED YOUR WATER PUMP IT WIL PREBENT FUTURE PROBLEMS. BUT DOESN'T MEANS THAT YOU NEED TO CHANGE WATER PUMP.
4helpful
3answers
Do you have to change the water pump when changing the timing belt/timing?
You don't have too, but not bad idea, the timing belt drives the water pump, if you just replace timing belt, and not water pump, water pump could go out and mess up the timing belt, now it has to be done all over again, timing belt, water pump and labor.
2helpful
4answers
2003 kia rio- water pumps
I would follow the mechanics recommedations. I think he's taliking about the cam and crankshaft seals. Yes the water pump should be replaced as well. The pump that sprays windshield washer fluid onto the windshield is called the windshield washer pump. The water pump is on the engine and pumps water (coolant/antifreeze) through the engine to the radiator and heater core.
4helpful
3answers
Do I change water pump when having timing belt changed
I would go to auto zone and get a diagram and the timing belt and do it yourself and the water pump (no it does not have to be changed everytime the timing belt is changed but if the car has over 60,000miles then it is best to change them both) it is not that hard especially if the car is not out of time just make sure you disconnect the negative side of the battery
24helpful
How to change a water pump on a 1999 Buick Century 3100?
the water pump on the 3.1 isnt to hard to change ...
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling system into a suitable container.
  3. Remove the drive belt guard.
  4. Loosen the water pump pulley bolts before removing the drive belt. This should help keep the pulley from turning as the bolts are loosened.
  5. Remove the drive belt. Remove the water pump pulley bolts and remove the pulley.
  6. Remove the water pump bolts and separate the pump from the engine front cover.
1helpful
Leaking water pump
leaking water pump was standard for that year.
Changing it without changing of taking of the cam belt shouldnt be a problem. but wen u get the new water pump make sure it the same cause in changes from serise 1 to serise 2
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
