Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to find my manual for my Northstar 5500 PPG Pro Series (GX Series Commercial) Generator. Bought it 5 years ago. Running like a champ now (for first time) and just can't find my manual to learn things like - how long it will run with full tank and when do I put in new oil (how many hours before adding more oil. I have tried to find manual on line but cannot. Help me please.
Kelly
Level 3:
  • Master 3,740 Answers
  • Posted on Aug 29, 2011
Kelly
Master
Level 3:
Answers
3740
Questions
Helped
2161891
Points
12091
I am just closing this out. Asker has manual.
Kelly
KHITTA
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Aug 12, 2012
KHITTA
Expert
Level 2:
New Friend:
Answers
61
Questions
Helped
23375
Points
146
Though without the mannual its really difficult to guess the things but as an expert I will suggest that as far as the engine oil is concerned you should check the level after every ten hours of running if its less than top it up but it should be compleatly replaced after 40 to 60 hours of operation depending upon the conditions you are using the generator if the operating conditions are dusty winds type change it around 40 hours otherwise you can continue up to 60 hours and fuel wise it shoul give you 1.5 to 1.75 liter per hour on rated load if you are on one forth load than it should go five hours on a gallon
13 hp honda engine on a North Star 8000 Generator ppg Pro series generator - generator keeps cutting off
Hi!
We have a put together a guide here to assist you in these situations. It will guide you through testing and repairing the Generator. : https://www.generatorguru.com/need-help/
If you need any further help our Generator Engineers are happy to assist you.
Regards,The Generator Guru Team
Parts Spares for Generators and Small Engine Machinery
3answers
Where can I get a service manual for this product. Or at least a schematic?
Free download on the internet. Search " North Star 8000 PPG owners manual". It is 11 pages long.
Adustments engine speed low rpm
You cannot adjust the voltage output. All generators are rated for 110-125 volt recepticals and usually have at least one 220-240 volt receptical for special appliances that require it such as water heaters, pumps, welders, air conditioners. When one of these higher draw appliances is connected and they begin to draw amperage, the gas engine will automatically increase rpm to produce enough amps. If your generator gauge is showing low voltage such as 60,80 or 90volts for example, then you have overloaded the generator and blown a capacitor, resistor or similar item.
1helpful
How much output can i get from northstar 5500 ppg generator
there are two things in generator out put
one is max out put which is 5500 in your case and another is rated out put which should be about 4500 in your generator Max out put should be used only for a little time say half an hour otherwise generator is suppose to run on rated load or rated out put which is 4.5 kva or 4500watts in your set that also when you are in Ideal conditions means if you are at the sea level if you are above in altitude you can calculate that engine will loose its efficiency at the rate of 3% after every 1000 feet altitude inthat way you can calculate how much rated load you can put on the generator
Oil type, amount, and frequency change on northstar 5500 commercial generator. How far up dipstick should oil show?
Depends on markings, oil range may b slotted lines between 2 vertical lines or 2 dots, or even the letter F.
Aug 31, 2011 • Garden
Need the manual and instruction to startup / setup have a northstar 8000 ppg
I believe this is it. If so please rate my response and give me a thumbs up!
http://www.northerntool.com/downloads/manuals/165914.pdf
1helpful
I have a 5500 ppg generator that won't start. I've verified the fuel lines to the engine are delivering fuel, but won't start. I've been able to pour a small amount of fuel down the carb...
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
How to flash field north star 5500 generator
wire a 120v 15a to 9vdc or 12vdc battery make sure you have no voltage out of the 240 side. with the unit running plug into the 120v receptacl QUICKLY pull out. check power out put. if it did'nt work check your battery, than do it again twice as long. you must check all component before doing this to make sure you don't have any other fail-er. this is danger-us be careful. good luck
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Top Northstar Electrical Supplies Experts
Sean Wright
Sean Wright
john h
CJ Rock
CJ Rock
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
