Question about Netopia Computers & Internet
Our Netopia keeps going "red." It will somehow go
SOURCE:
Shuttle83
  • 1139 Answers
SOURCE: TV keeps turning off after 30 seconds
This is usually a sign that a function has not completed or a switch has stuck in an incorrect position. eject can only happen if the sensor (either optical or mechanical senses that a tape is present. The swich might be stuck or the sensor might be blocked or bad. You can open up the unit and try to determine if the sensors are not being blocked by any of the mechanical parts of the unit. You will need the service docs to show you where the components are located. I hope this helps. Shuttle83
Posted on Sep 06, 2007
spincycleus
  • 62 Answers
SOURCE: netopia router test page keeps poping up while i'm on line
You can try enabling your pop up blocker in internet options, but this is a problem i have never heard of before, and now i see that 3 of my people have it.....hmmmm
The proper method to bring resolution to the issue is to reset the modem. If it keeps doing it, you need to call your ISP and have them swap it out. If its a netopia 3347, those are new, it only came out last year, call your ISP and have them swap it out, there shouldnt even be a charge. 1-877-SBC-DSL5, thats 1-877-722-3755. When you're prompted, say 'tech support' for tier 1.
Posted on May 01, 2009
spincycleus
  • 62 Answers
Reset your netopia by holding the reset button in for at least 30 seconds.
Reconfig your netopia again.
You do this by opening internet explorer. It will say "Page cannnot be displayed"
type 192 168.1 254 in the address bar (where you normally type www)
the username is admin
the password is the serial number on the bottom of the netopia
click on configure
click on quickstart
put in your userID like spincycleus@sbcglobal.net
and your password
click submit at the bottom
and then click the yellow triangle dealie at the top right
click save and restart the database
when it comes back on in a few minutes, you'll be online
If this doesnt resove the issue, then your firmware is messed up and its time to swap out the netopia.
spin
Posted on Jun 22, 2009
kamal1984
  • 1383 Answers
SOURCE: where is the reset button and why does my router keep going off
you can find reset button in back side of it.
Press reset button for 10 seconds you can press it with niddle .
Then ci\onfigure it again
You can access your router with
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
thenh configure it as your isp settings.
Posted on Aug 01, 2009
SOURCE: I am trying to play racedriver grid online,keep
it's all a tecnical issue and Codemasters say it won't be fixed before the end of this weekend.
It's all in the official forum:
http://community.codemasters.com/forum/showthread.php?t=369465
Posted on Aug 02, 2009
We changed the battery but a small red piece of plastic fell out. It goes behind the plug-in port somehow but after much effort, we haven't been able to put it together so we can sucessfully charge it up...
The red piece is the voltage switch. It goes at the bottom of the shaver and the rectangular part will correspond to the rectangular cutout at the bottom. The copper contacts will go against the circuit board
Jul 01, 2017 | Norelco 3605 X Electric Shaver
Somehow I have "locked my microwave - when I try
Easiest thing to do is to unplug it or turn off power at breaker for a couple of minutes, should reset.
Nov 14, 2010 | Sharp Microwave Ovens
Cannot connect wi-fi phonr to it says i need wep manual missing
Hi Dona,
In order to find the WEP of your Netopia router, first we must find the default gateway address.
To find the IPaddress in your comp Please follow this,
1.Go to the Start menu, go to Run, and type "CMD" in the dialog box (without the quotes).
2.Now you should see a dark (DOS) window.
3.Without the quotes, type "IPCONFIG" and press ENTER, where the cursor blinks.
4.Now you should see some network information, along with the DEFAULT GATEWAY of your computer listed.
5.Open the browser,ie: internet explorer in the computer.
6.Type in the DEFAULT GATEWAY (Eg: 192.168.1.1) in the address bar of the internet explorer and hit enter.
7.You will be logged into the Netopia router setup page where you can check the security on the router, when you click on the security option
Thanks & Regards,
Prema
Oct 17, 2010 | Netopia 2247NWG-VGx Wireless Router...
Netopia-wireless usb card model:ter/gusb-n p/n:8960015-00-01 need update drivers
I put the USB into my Vista machine, and it installed the driver. The actual message read, "RT2500 USB Wireless LAN Card installed" (without the quotes). Hope it helps with XP as well.
Aug 17, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
Netopia router test page keeps poping up while i'm on line
click on configure
click on quickstart
and your password
spin
May 29, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
My website on my network open the netopia router page
You need to somehow setup the internal DNS to route all requests for the specific domain name, to your internal website.
Or, setup the netopia to allow loopback connections.
If you have a 2003 Server OS, chances are that the server is handling DNS requests, at least internally.
This tutorial has a good example of how to create domains internally:
http://www.simongibson.com/intranet/dns2003/
Just a couple of tidbits when using this approach:
You will essentially be controlling the DNS for the domain internally anyways. Meaning, any subdomains, mail exchangers etc., for the domain will have to be configured as well.
Good Luck.
Feb 26, 2009 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Netopia 3347 moved to a different location/tel number
If you got the netopia in anyone of the 13 states that ATT controls, then that netopia will work in any other state, not just the phone number it was attached to. We are implementing technology now that it will be phone specific, but most people dont have that installed yet.
All you have to do is reset the netopia, open a browser, type 192.168.1.254 and set it up with the new username and password you created when you got your new DSL service.
spin
Feb 18, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Dec 09, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Computers & Internet Logo
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
marty morrison
marty morrison
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
