Turned the set off, now it will not turn on
Failing power supply-
Nearly all modern electronics uses a 'switched mode power supply.'
They are more efficient, also much more prone to failure but offer the added benefit of being designed so a 'downstream' fault will cause the supply to enter a cyclic state to avoid setting fire to your home.
The supply itself will also cycle if it has an internal problem; once again, to prevent destroying itself or anything dependent on its outputs.
Supplies built a couple decades ago could only do this by blowing a fuse and there are conditions that can occur that would not blow the fuse but would allow overheating and further damage as well as fire.
The most common failure is of electrolytic capacitors which sometimes will show their illness by causing a bulging top or depositing a crystaline trace around their base.
Often though, they show no outer signs of failure but their value can shrink to tenths of a percent of the specified due to poor seals and defective chemicals. These can only be found through measurement with a capacitance meter with a DF (dissipaton factor - loss) capability.
They will be in size from ~ 3/8" to 2" in height, ~1/4" to 1 1/4" in diameter, cylindrical, perpendicularly mounted on the board.
They will have markings on their shrink-wrapped sleeves (color can be any) and range from ~ .1 to several hundred uFd. with voltages from 3-4 volts to hundreds.
Power supplies are often mounted on a separate board (since they are often outsourced) so if you are adventurous, take the back panel off and take a look.
I had the same problem even the remote will not turn it on we borrowed another tv and three days later, i was going to get rid of it then i decided to plug it in one last time to see if it would work the power button on tv i pushed to turn on and it went partially in the tv and came on and has worked so far. I have to use the sattilite remote to turn it on since the power button went in the tv partially. I have already took on tv back because of this reason it seems after you have it for about a year it starts acting up. Try unpluging and turn on later.
i turned my tv off last night and now it will not come back on. The red light on the front only flashes when i press the power button instead of turning the tv on. the tv is also making a wierd high pitch sound.
