what driver does it use ? can you print a configuration page from the device and compare the printer languages used. Example PCL 6 , PS . Is the driver matching the accepted languages the printer requires.
Was the jam in the Fixing/Fuser Assy.? Because a E007 is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error.
error codad E007 First make sure fuser plastic not damage? Or not move the proper place? if damage fuser plastic Replace by new one if the fuser plastic not damage keep proper place. fixing fuser film is worn out or broken remove the fixing unit ang check the fuser film if its worn out broken replace a new one .
Hope this helps. Please rate my response. Thanks. Have a good day
you need to reinstal the firmware on your machine, And for the E007
check if the new film is rotating in the same speed as the presure
roller, check if you mounted the film sensor corectly, and if the sensor
is reading the corect end of the film ( it schould be the one whit a
white square on it).
fuser plastic move keep proper place.
