We have the same exact problem with the same TV. We've only replaced the bulb once about a year ago. Don't know if it had anything to do with the fact that we now have a large yellow circle in the middle of our screen, which is about 7" round.
We only noticed the yellow mark about 4 months ago.
Hopefully someone will have a solution for us that doesn't cost an arm and a leg. Paid $2100 for this set and are a little disappointed.
Probably had too high wattage bulb and basically, it burned the lens cover. Remove the old lens and "project" to see if the yellow circle is projected. Iif so, purchase a new lens cover.
Your light engine is bad and needs replaced. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
you have what sounds like a very simple fault .the positor has failed a cheap three leg device in the power supply .it keeps magnetic feilds from effecting the crt/screen unless your confident with a soldering iron i would get an engineer as it is a very inexpensive component...if you need any more help drop me a line farr64[colin]
When tv has a blue or red or yellow circle in middle of screen and it is very faint looking in most cases it is the light engine.
The cost is 650,00 plus labor. In some cases it could be the color wheel. but rear .
The lamp is not the problem
thanks doctor video leading edge electronics snce 1987
