Diesel Leather Strap DZ1147 Aa Watch for Men Logo
Posted on Aug 29, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dead Battery - Diesel Leather Strap DZ1147 Aa Watch for Men
Anonymous
Level 2:
  • Expert 75 Answers
  • Posted on Aug 29, 2011
Anonymous
Expert
Level 2:
Answers
75
Questions
0
Helped
16329
Points
225
Any jewelry store can open the watch and install a new battery.
1helpful
Hello i have replaced the battery on my tissot t touch expert & display not working? Any suggestions. Battery was completely dead before change?
If the battery was dead too long the fumes from the battery might have damage the electronics and that's not good it will have to go back to tissot for a new movement What I'm going to tell u is very inportant. Never let a watch set dead I don't care if it's a windup or an automatic or even a battery watch. U must always keep the running because all the lubriactions will set up and not performed properly. Just like a car setting dead too kind In ur case the battery has cause the problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gerald_b9936683ef6d97c6
The hands on my watch are not working. i assume the battery is dead???
yes your watch battery is dead and it has to be replaced by a new one. i hope i had been helped you.
The display went blank, changing battery didn't bring it back to life. I have 2 of these watches and have successfully changed batteries before, despite the tricky process. is this watch dead?
Unless the new battery is dead that would explain it, but assuming the battery is good it indicates a failure in the electronic module and should be considered done.
Jun 27, 2011 • Watches
I just replaced the battery on my Timex WR100 watch, but can't seem to reset it correctly. There is a sticker on the original battery "AFTER BATTERY INSERTION SHORT AC PAD AND BATTERY (+) TO...
It sounds like you're not far off. Peel the sticker back a little, and see if there is a small contact point (usually yellow metal) - this should be marked 'AC'. Short this to the + for 3 seconds, then repeat for good measure. If that doesn't sort it, try taking the battery out, wait about 30 seconds then put it back in and reset if necessary. If there's still no display, obtain a known working battery and try again.
If you still have no display, it's time to give up and admit it's dead.... unless you've been using a plastic coated paper clip.
Good luck.
1helpful
Installed battery in lorus musical watch and nothing.
mcdevito75 here, A quartz mechanism can go bad just like a light bulb, depending on the watches age, wear etc. If your watch was stored for a period of time with a dead battery in it, that dead battery could hve leaked, ruining the mechanism. If your watch worked fine and the battery just went dead, make sure the battery contacts inside the watch are clean, use a Q-tip dipped in Alcohol and gently clean the battery contacts, press the button for the music part of your Lorus and make sure those contacts are clean and are meeting once the button is pressed, this you can see with the back cover off the watch. Makes sure the battery is installed correctly, and that the new battery number is the same as the old battery number. 364 and 371 are popular batteries for Lorus musical watches, even though your new battery is new, it can still be dead, who knows how long it was on the store shelf?? also, double check as some Lorus Musical watches have 2 batteries, 1 battery would be rather large ans sitting just under it"s hold down bracket see, as soon as you remove the back cover, if so, that battery must also be replaced. I have an old Mickey Lorus musical useing a 397 battery just 1 but my Lorus is burnt out. If all this fails, I would look for a small watch repair shop in your area and have them look at the watch for you.
Feb 18, 2011 • Watches
Dead battery, how do I open?
I believe a local watch repairer will replace the battery for around 5$ that should include the battery, depends on the person.
Generally the battery is replaced by opening the back cover of the watch, in some cases special tools might be required.
the details of the battery read on top the one currently inside it.
Jan 30, 2010 • Watches
Battery reads 2.85 is it dead?
I am assuming you have a lithium battery and they test good at 3. Since they can die off slowly i would replace it as it may not have enough to power your watch. These will typically need to be replaced about every two years or so.
Sep 19, 2009 • Watches
2answers
Dead battery
take it to a qualifed watchmaker or send it to fossel.This watch is water resitant and MUST be tested to insure that it remain that way.
Top Diesel Watches Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Diesel Watch Expert? Answer questions, earn points and help others
