You don't need a battery you need to clean or probably replace the sparker. You can get them at Lowes or Home Depot or similar stores, or on the web. They are pretty cheap. Can you see a spark when you push the button? .https://www.riverbendhome.com/rbhitem/182968*1?CAWELAID=120204730000005214&CAGPSPN=pla&CAAGID=38136449942&CATCI=pla-48215642774&gclid=Cj0KCQiA2NXTBRDoARIsAJRIvLy-nfIkDaDWnijP94Ea3JXkfAhkCmRlAakDfXKZnjk7EzfA2s4zs6kaAvKuEALw_wcB
SOURCE: Low Gas Pressure on Smeg Range cooker
there should be a regulator on back of the stove where the gas line connects.you will see a plug that unscrews,remove this plug and run the unit.if this solves your problem clean the plug really good and put back on.
SOURCE: How to replace a thermocouple in a New World
not at all hard to replace just have a few small wrenchs on hand 10mm 7/16 maybe 1/2 in and screw driver. how do you know its a thermocouple problem, theremocouple are on commercial ovens and basic ranges usually a domestic range has a glow coil operating oven and not a thoemocouple
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing the Igniter
heatman101
