- To unlock you Nokia 2690 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
my imei number is 353387044369597 i want to unlock my nokia 2690
please help! i am not able to unlock my phone. i am typing the correct code and still it isn't unlocking. my imei no is 352010/04/003247/9.
my imei number is 358260030068454 i want to unlock my nokia 2690
My imei no is 353795/04/443381/9 please help me mere mobile me lock of kare ke bad code kho gaya he use kese nikalte he muje pls batao na. Thanks
my imei # is 353753046238173
Hi, didn't mention what set are you using, if you are using Nokia then use this Master Code : 2567252147
sir my ime no is 354869/04/867332/1
thnx thnx thnx thnx thnx............
this is my imei:355954/04/882430/3 i need the master code please
this is my IMEI 354306/04/316927/8
Hello i badly need your help as soon as possible My mobile IMEI is: 355392049296637
my IMEI is : 355392049296637
my imei no.353387/04/151214/0
my mobile nokia 2690
my imei num. is 354307/04/617602/1 ... plz help
Help me please...lost my code too...
my phone's imei code is 352687/04/449568/5
My emi 353409043122585 i miss the securitycode plse help me
My imei no is 353411045755446
My imei no. Of nokia 2690 is 352010043469769 please provide me master code.
SOURCE: forget my security code for
Hard reset
Back up your personal data with PC Suite or to the memory card first!
Switch-off your phone.
1. Press and hold three keys at a time;it is called "3 finger reset" which is depress these three keys simultaneously "*" "3" "green phone" and then power on phone whilst keeping those same three keys depressed until you see formatting.
If you dont understand, again follow the step.
You will use three finger for pres three keys ."green phone"+ "3" +star( *) and pres the power on switch.
All switch will be pressed at a time.
Soon an formatting text, will appear ,then stop pressing those switch,
Remember.
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory stetting.
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate and leave a short comment,that is your choice.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
SOURCE: i forget my nokia 2600 security code.
I also forgot the security code of nokia 2600 my IMEI Code is 359314028589846.. please help me..
