Powerware 9120 UPS System Logo
Posted on Dec 03, 2017
Hi, I have a ups powerware 9120, 3kva. It has an EBM(external battery module). This UPS 9120 was recently replaced to a newer model, Powerware 9130, 3kva. The problem is, the connection for the EBM is different from the new UPS. Can you please give me some advice how to modify the connections so I can still use my EBM.
5 Related Answers
Richard Roberts
  • 198 Answers
  • Posted on Feb 23, 2008
SOURCE: Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Anonymous
  • 189 Answers
  • Posted on Nov 06, 2008
Greetings!
How many years is your ups working? UPS is usually run by a battery, some of them are disposable and needs replacement. If it does not charge anymore it needs replacement of battery.
Thanks.
Alan Hood
  • 195 Answers
  • Posted on Mar 03, 2009
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
upspro
  • 25 Answers
  • Posted on Jul 11, 2009
SOURCE: control board for powerware 9120 6kva ups
did you get what you needed?
Anonymous
  • 4 Answers
  • Posted on May 27, 2010
SOURCE: replacement fans for powerware 9120
9120 fans are rare and uncommon, for alternate solution just replaced the bearing of the fan.
Powerware ups 6kv indicates Bat disconnected
1st does this have external battery modules or is it only the Internal batteries on this unit? You can disconnect the EBM's and the unit doesn't alarm even removing the internals with EBM;s attached won't cause an alarm. But it you only have internal batteries, open the front cover by pressing in the sides on the bottom left and right and pull it out and up at the same time revealing a black cable with a small anderson connector, make sure it is connected. you can pull the batteries out to check them to be sure they are properly seated. By the way the UPS in the picture only went to 3000va so is the 6Kv a different model?
Eaton 9130 ups alarm #191
Open cell in the battery.
The batteries need to be replaced, or at least the most bad battery!
Pawerware 9130 alarm 191
need to change batteries.
cannot hold charge
2answers
Alarm #191 open cell voltage powerware 9130
Remove the front panel plastic cover where the batteries are located, then plug the two connectors together, restart the UPS, and it should be fine.
Bc bus fault of 9120 2KVA
Suspect charger board failure. Replace with new model 9130. 9120 is obselete
Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
Donde puedo conseguir el manual del equipo powerware pwi-9130 3000R
Try www.eaton.com/powerquality. Choose Mexico as your country and then 9130 rackmount as your prouduct. Documentacion tab.
I need qty:10 from ups poweware9120
The Powerware 9120 UPS has been replaced by the Eaton 9130 (www.eaton.com/powerquality). You may be able to get some 9120 models from www.powersupersite.com. Just do a search for 9120.
Top Powerware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
