SOURCE: Doesn't turn on!!
I have the exact same problem with my E815 Motorola...only had a month or two, forgot to charge and battery went dead. Now moto screen comes on for about a second and dead? Try to get to boot loader, same thing...dead.....Bob
SOURCE: Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
SOURCE: Krzr won't turn on
I would inspect your connectors (both charger & phone) as well for dirt, debris, or damage.
I would also suggest using Motorola's wall chargers, the products seem to charge best with them rather than the after-market knock-offs which also seem to damage the phones connectors on some models.
If there is damage to your connector , you will need to get your phone serviced.
SOURCE: Motorola Hint QA30 won't turn on/Motorola screen flashes
Same problem here!!! I was in the middle of a text and it shut down outta no where then i turn it back on and it just flashes the purple circled M at me....I dont have a warranty on my phone but luckily I called alltel and they sent me a box to send the phone back and they are replacing it free of charge. I love the hint its my favorite phone of all the phones ive had....alltel always satisfies its customers in the end and ill definatly give the hint another chance...bottom line...call alltel have them send you the return box and mail it to them wait a week and you got a new phone!! good luck!
1 - Switch ON your Motorola Karma QA1 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Karma QA1 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Karma QA1 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
