This IS tricky. You have to place the "L" shaped pin of the spring into the hole in the middle of the wooden looking contact switch. Then put the zigzaggy end of the spring into the hole in the on/off switch. Place the big hole of the wooden looking over the dowel on the "switch" side. Now the trick is to do all this and hold it together while replacing the top magnetic part of the motor. This will hold it in place. Them put the rest of the motor in. screw and your done. Hope this was helpful
That is tricky and i do this for a living just call me at 813-310-6211 my name is jaime il try to talk you threw it
I understand how it goes together. I need a picture of the spring to be sure mine isn't broken.
I'm trying to find how the spring goes on the switch
same
