The first step would be to clear the CMOS ram manually. To do this, you need physical access to the mother board.
- Make sure the power is off but do not unplug from power.
- Locate Clear CMOS (JBAT) Jumper. From above, lower right hand corner.
- Simply remove the jumper and put it back again.
- Power up.
- If problem persists:
- May be faulty ram
- If you have a video card installed, uninstall it and connect monitor to VGA port of motherboard. It could be a faulty video card.
- CPU could be over heating, clean with compressed air, check fans and CPU grease.
Hope this helps...
