Question about Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo
My DVD player won't play my DVD's
One day it would play DVD's and the next it wouldn't. I tried to a lense cleaning DVD and I tried different DVD's, but it won't play them anymore. I called Tech support and all they could tell me was to make sure the disk was clean and that it was the correct region. Is there any way I can fix this on my own?
  • 7 more comments
  • spaceranger Nov 19, 2007
    Mine plays some with no problem, then when I put another DVD in , which played on it before it says ,please check disk.
  • Anonymous Jan 22, 2008
    Put DVD in, screen says loading disk, then it ejects it without an error on screen.
  • Anonymous Feb 25, 2008
    My DVD won't play any DVDs, sometimes it will but mostly won't . Get error message minute we put DVD in. Got cleaner disc, but got error message on that too! Help?! Can we fix this or do we just need to buy another DVD player to hook up?
  • PAC MOMMA Mar 12, 2008
    My DVD player says "This type of DVD can not be played. Please insert a different disc."
    What can be done with this? HELP PLEASE! This TV is for the kids and they all bring their DVD's not VHS's
  • ChadV Sep 24, 2008
    I can't get any DVDs to play. When I put one in, it says "Reading DIsc" but won't proceed. I don't think the disc is actually spinning inside. I suppose I will need to have it opened up and looked at.
  • Anonymous Feb 12, 2009
    Anyone have a link to a video (or pics) showing how to get to a  laser head?  I have the cover off my samsung v5500, but I don't see the laser head, to clean it.
  • Anonymous Mar 06, 2009
    my dvd player plays cds but not dvds
  • lesleyhut498 Apr 05, 2009
    My dvd player and my dvd player on my computer won't play rented, burned or cd's anymore. I have no idea why. Is it a virus?
  • Jennifer Aug 17, 2013
    i have a portable DVD player for my car and I put it in and every disc says reading disc error.
    New Friend:
My dvd plays cds but not dvds. Any help is welcome!
Posted on Sep 07, 2010
    Problem Solver:
  • 15 Answers
It's the laser i just manually replaced my laser on my hi fi system, it first stop reading burnt cds but will play original cd's and dvd's. Next the dvd went won't play dvd burnt or original. Then it started a few days later to have problems reading original cd's. So i was curious what was the problem, could it be a build up of heat in the system damaged a microchip, or is it the laser gone. Not an old system. So i took out a laser from a magnasonic dvd player which reads both cd's and dvd's and stuck it into my isymphony system. After some alignments, and reconnecting all cables, i was surprised to see it play dvd's and cd's again all formats. So i guess as long as you get a replacement laser that is capable of reading the same type of disk that the original can, then you should be good. I mixed a magnasonic dvd player laser with a isymphony system and all went well. No skipping, read's tracks quick no delay. So i suggest if you have a little expensive system like mine $400.00+. Go ahead and replace the laser, if you have a cheap $60.00- dvd player replace the dvd player if you got the money, replacing a laser ain't fun and takes alot of patients. If your working with a hifi system i suggest you be very careful especially with one that is capible of pushing though alot of wattage if you accidentally touch a capacitor or transistor's terminals then you got a good chance of injuring your self. So for the user above, just buy a cheap 10$ dvd player or get one of those xbox 360 replacement laser's from ebay which sell of $6.99 it will do the same job since the microchip on the system is what holds all the codec's for the formats that it will read. Just make sure you get one that reads both dvd and cd's. Most likly a xbox 360 replacement laser will read both cd's and dvd's. Try it, just be careful and make sure you align everything properly. It ain't that hard. Like the user with a tv/vcr/dvd system best bet is to replace the laser instead of the whole system. Going to cost you with shipping from ebay 15$ for a laser. CAREFUL of you work with a tv keep it powered on and unplug it from the wall with out pushing the off button. Then wait for an hour to let all charges discarge. Cause if you was to accidentally touch a wrong part inside a tv, you'd be thrown back far. Becareful, and do everything at your own risk.
Take Care
Posted on Jun 24, 2008
    President:
  • 3,130 Answers
Not unless you know your way around a cd or dvd player. I found that in alot of problems are the pick laser assys and most are not worth the cost of the replacement. Just an example on a 29.95 sony discman The laser pickup cost 45 Bucks.+ labor for install and alighnment.. now in the earlyer units the laser had a small control on them and when they got weak you could increase the laser power. or they drive train for the pickup as the mechanical gears or motor woukld get full of dirt. You could always take it apart as long as your carefull and dont care if you ruin it or not BUT I do not recommend it as there are super fine wires and ribbon cables inside these puppies that even a sneeze while holding one while open could rip a ribbon cable. The only thing you can really do with a cd or dvd player is to clean them with a lens cleaner unless you have some know how on alighnment of there circiuts. You could always get an inexpensive external dvd player and hook it up to the set.
Posted on Mar 26, 2006
I took the Initial tv/dvd apart. The dvd player is removable and could be replaced if you could ever find a replacement. I took the dvd player apart and temporarily fixed it. I noticed the drive was not spinning. For kicks I pulled the laser head from full-in to full-out and put in a dvd. It played!!! But only for a few minutes, then it froze. Head frozen in full-in position again. I repeated this with a different dvd, same result. My conclusion is that the dvd laser head mechinism jams in the full-in position. Either that or it doesn't slide freely causing the data stream to stop, thus freezing the screen. This all started when I loaded a data-dvd by mistake. Could that have jammed the laser head and started the problem? Just a guess. Final answer -- hook up an external dvd player. Anyone know where to buy a replacement internal dvd player?
Posted on Jan 22, 2008
I found my replacement DVD player at; http://www.shopjimmy.com/
Posted on Jun 05, 2009
  • barbsmajek
    barbsmajek Sep 19, 2013
    My DVD player wont play all the way through an 8 hour or ten hour DVD.
4 Suggested Answers
SOURCE:
  • 43 Answers
SOURCE: Problem with the dve player
You may have to check the options for the player. Some DVD players cannot play formats other than regular DVDs. You can check the options to see if it can be put in a different mode from the normal one, such as progressive scan, which can help it to read DVDs better in some ways. You can also set it up to accept more types than just DVDs, but also DVD-Rs and VCDs. I cannot tell you, without fiddling around with it, whether you will need to take it in to a shop, but that is an option. Once you see about adjusting some of the settings, see if it won't play a DVD.
Posted on Oct 23, 2009
  • 734 Answers
SOURCE: dvd
Describe model number of your DVD player
Posted on Nov 11, 2008
tvtek
  • 1284 Answers
SOURCE: DVD player cannot read DVD disc.
Have you tried other DVD's in this unit and they work? If so it might be just an incompatibility issue with that DVD in your TV.
Posted on Nov 26, 2009
Won`t play dvd`s.try a cleaning disc no luck!possible dvd diode gone?any help please.Nigel...
Hi Nigel,
There are three reasons for discs not playing.
First, if the set has been lying for some time, the loading belt becomes lose and the loading is not complete. The result is no disc play.
Second, there is dust on the lense. Again the result is no disc play.
Third, the lense unit has gone bad or weak. Here also the result is no disc play.
Jan 24, 2016 | Televison & Video
Disk won't load
First make power reset.
  • Switch off your DVD, remove power card from wall out-let. Then connect again and power-up.
  • Use CD/DVD lense cleaner to clean the lense.
  • Then try out.
Thanks
Iqbal
Apr 29, 2008 | Sony RDR-VX530 DVD Recorder/VCR
DVD Writer Model SH-S223 hangs when playing dvd.
Welcome to FixYa
Dear User
You have to Use a Lense Cleaner CD to Clean your Lense.Still same Problem Exist ti seems to Some Codec Problem.Try in Different Player.
Again Same Problem Send it for Repair/Replace....
Hope this Helped ...thanks for Connecting FixYa..
Oct 16, 2010 | Samsung SH-S223Q DVD-RAM Burner
Dvd player won't play disc
There are a few different cleaning kits out there these days for DVD or CD players. I would recommend one that actually has fibers on it so the it brushes the lense of the DVD player. These cleaning kits can be found just about anywhere. Have you tried to clean it with anything?
Jan 12, 2009 | Samsung DVD-V4600 DVD Player/VCR
Dvd plays but stop for a few seconds then starts again
Try to clean the lense of the DVD with a dvd cleaner disk .
Jul 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Philips HTS6510 dvd player useless ..
This is because you DVD player's lense got too old. Try to clean that with a good Lense Cleaner. If the problem persists, change the Lense for the same.
Feb 04, 2008 | Audio Players & Recorders
Cannot play dvd
hy
try to clean the reading lense with a special brush cleaning cd.
youll find it computer stores.
most of the cases it works
bye
Feb 03, 2008 | Televison & Video
DVD player keeps skipping and gets very blocky looking and then sometimes it just stops I tried cleaning both the lenses of the dvd player with dvd lens cleaner disc and cleaning the dvds nothing seems too...
It sounds like the problem is with the DVD's you've been playing. I've gotten those problems before, but not on every DVD. How many different ones did you try playing?
Jun 16, 2007 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Dvd does not play, firmware does not reconize disc
The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 02, 2005 | Emerson EWD2204 DVD Player/VCR
Panasonic PV-DF2704 27 in. TV/VCR/DVD Combo Logo
23,589 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
