HP LaserJet 3055 All-In-One Printer Logo
philip Posted on Jan 07, 2018
Re; HP LASERJET 3055 every morning I now have to reset the machine (power off & then power on the machine) in order to receive faxes, during business hours, if i do not follow this procedure, i will not automatically receive faxes Power save time is set to 12 hours. please give me a solution
5 Related Answers
Anonymous
  • 105 Answers
  • Posted on Jun 19, 2008
SOURCE: How to reset an HP LaserJet 3055
If you go in your user manual to page 241, it shows the following instructions on how to reset the printer to factory defaults. One important note is that you will lose EVERY stored piece of information including phone numbers and such.
To restore the factory-set defaults
1.
On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Service, and then press .
3. Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
Hope this does it for you.
checkitright
CheckitRight
  • 1363 Answers
  • Posted on Jul 16, 2008
SOURCE: HP LASERJET 3055 Manual IP Address not saving
Try doing a cold reset first, then check that DHCP is manual not Auto. then try to input IP address again. If the Network card is seperate then you may only have to replace the Nic
Anonymous
  • 61 Answers
  • Posted on Jul 24, 2008
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Anonymous
  • Posted on Mar 23, 2009
SOURCE: Scanning on HP 3055 printer/scanner/fxx doesn't wrk with vista
I am unable to scan in pdf format under vista window
Anonymous
  • 102 Answers
  • Posted on Jul 01, 2009
SOURCE: HP LaserJet 3055 scan over network.
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=1161389&prodNameId=1140780&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-38114-4
Thanks and Regards
Neeraj Sharma
1helpful
HP laserjet 3055 Have dial tone. With phone can call out and receive calls. When sending fax keep getting Result: No answer
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
We just bought a new HP laptop. We have an HP
yep the best way anymore is throught a usb port
Our fax machine is displaying the incorrect fax number for our company on the report. How do I change it? We have a laserjet model 3055 all in one printer. Thanks Jenneka
Go to www.hp.com, select support & drivers, select "see support and troubleshould........", fill out your product and you'll find "setup, install and configure".
Gerrit Jan
2helpful
2answers
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Hp laserjet 3055
There are a number of reasons for this. The basic ones are:
1. You are using a splitter to split the line between your fax and the wall outlet. These are NOT supported.
2. You may be using a phone line (RJ11) cable that DID NOT come with the machine.
These two reasons are probably the most significant reasons why the fax will not receive.
Here is the link http://is.gd/1jC8H to the HP page for all things 3055. You should read the back of the manual for troubleshooting "Not receiving faxes"
Start with a fresh phone line, no splitter, directly into the wall outlet. If you can trace the wall outlet to another splitter in your basement or elsewhere in the house, then that is STILL considered a splitter, and is unsupported.
1helpful
2answers
Someone is faxing me iam getting commerror283 how to fix it
This error typically indicates a problem with the line. Sometimes it's caused by noise (like from DSL on the same line, or alarm systems/home automation systems that use the same line).
Try other devices on the line, like a standard phone or modem and see if you can detect the noise issues. You may need to order a separate POTS line for faxing, especially if you are using the aforementioned services or VoIP systems.
Hope this helps!
HP 3055 Lasrjet
receive set to manual set to automatic
Hp-laser jet 3055
hi, just try to reset the memory the of fax. i think that's the cause that's you cant send and recieved fax..i hope it would help you...
2helpful
3answers
3055 scanner not working
My HP 3055 cannot scan but can print & fax.
3answers
My hp 3055 has not been receiving any faxes
The only thing that I can think of for you to do is to completly delete it from your computer & then re-download it. Only do this if you get no other resolution. Or you can call 1-800-474-7739 for hp technical support. I just did & they were a great help to me!
k24674
Grand Canyon Tech
Grand Canyon Tech
