Question about Cell Phones
I was told my password should be 9999 until I set it and it tells me its invalid password I cant set up my voicemail do to it
    Scholar:
  • 114 Answers
Try the last 4 digits of your phone number instead of 9999.
You can also dial 611 and request that the code be reset.
Posted on Aug 29, 2011
SOURCE:
Mailbox passcode is uknown. used admisitrative mailbox to reset the pass code. what is the new pass code?
This depends on the voicemail system. Here are some common default passwords for voicemail.
1234
0000
1111
9999
4321
7777
Hope this helps.
Jan 04, 2011 | Toshiba DKT-2020-SD telephone
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
How do you set your voicmail on the lgneon
To set up voicemail, push and hold the number 1 key until it dials into your voicemail box, then listen and follow the prompts to create a password and leave a standard or custom greeting. If this doesn't work, contact your carrier to reset the voicemail on your account. Hope this helps!
Jun 20, 2010 | LG Neon GT365 Cell Phone
Just one question! How do I set up the Voicemail?
First you'll want to verify that you have set up voicemail with your current service provider. If you've already taken that step, the phone is actually pre-programmed with a quick key to get into your voice mail box.
Press and hold down the 1 key, this will bring you to your voicemail, if this is the first time you're accessing it, you'll have a default password of either 1111 or 9999. Try either of those and it will then ask you to set up your new password, follow the voice command instructions and you should be on your way!
If neither of those passwords work, I would recommend calling your service provider and making sure that they don't use a different set of generic passwords.
Or if pressing and holding down the one key doesn't work for you, simply dial your own 10 digit number, and when you hear the voice telling you to leave a voicemail, press the * key and it will begin the login process as discussed above.
Hope this helps!
Dec 09, 2009 | Samsung J700 Cellular Phone
My phone asks for the pin number when i call my voicemail but i never set the pin up, how do i set a pin number?
The pin is probably one of the following:
9999
0000
1111
the last four of your phone number.
Once in your voicemail, you'll hear a menu and an option will be provided to change your password.
Jul 31, 2009 | Motorola Mobility i455 Cellular Phone
T7316E Voicemail Password Issues
Feature 983
password is: 1020000 (if you use 3 difit extensions)
OR
120000 (if you have 2 digit extensions)
Jul 09, 2009 | Nortel T7316E 2-Line Corded Phone
I'm unable to set up my voicemail message on my Motorola W385. When I enter my password, I'm told the password isn't valid. Help?
Press the "1" key and hold for a few seconds, this will bring up your voicemail.
Next, key the pre-set passcode of 9999, this will allow you to set-up your own message and passcode. The phone tells you how.
Mar 08, 2009 | Motorola Mobility W385 Cellular Phone
How to set up voicemail on i phone
<<This is straight from TracFone support for setting up voicemail on the Motorola C139....enjoy>>
Thank you for your interest in TracFone Wireless. We are responding to
your recent inquiry.
TracFone Wireless would like to take this opportunity to apologize for
any inconvenience this issue may have caused you.
Your voicemail box has been reset. To set up and retrieve voicemail from
your TracFone:
Press the MENU key,
Scroll to MESSAGE and press SELECT,
Then scroll to VOICEMAIL and press the MENU key,
Next scroll to VOICEMAIL SETUP and press SELECT,
The VOICEMAIL Access Number should be: +17044089979 and press the OK
key (if there is no + sign, please press and hold the 0 key until it
comes up).
If the numbers there are different, press and hold the key below the
word CLEAR or DELETE until all the numbers disappear from the screen.
Then enter the number 17044089979 and press OK.
After programming the Voicemail Access Number on handset, please turn
the phone off and back on.
Then, press and hold the 1 key to auto-dial the VOICEMAIL box to record
greeting and complete setup.
Your temporary password can be 0000, 1111, 9999, the last 4 digits of
your wireless number, or another 4-digit number easy to remember.
All calls made to your voicemail from your TracFone will deduct airtime
units. To avoid being deducted airtime, it is recommended that you
contact your voicemail from a land line phone, by dialing your ten-digit
mobile number. To retrieve voicemail messages from a landline phone,
please follow the instructions below:
1. From your landline phone, dial your TracFone Number.
2. When you hear the greeting, press the star (*) key. If the star key
does not interrupt the greeting, press the (#) key.
3. Enter your password and follow the retrieval instructions.
Please note, if this procedure does not resolve this issue, we would
need to talk with you directly for further assistance.
Should you have any further questions or concerns, please contact one of
our customer care representatives at 1-800-867-7183. For your
convenience, our representatives are available Monday-Saturday from 8:00
AM to 9:45 PM EST, and on Sunday from 8:00 AM to 6:45 PM EST.
Thank you for being a TracFone Wireless customer. We appreciate your
business.
Sincerely,
TracFone Wireless
Sep 16, 2008 | Cell Phones
Setting Up My Voicemail
Call service provider, they can reset your voicemail options.
Nov 12, 2007 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
