Hi, I've seen that issue before with the G11, it's due to faulty wiring on the circuit board and can only be fixed by a Canon authorized repair shop as fixing that issue is very involved.
Your Powershot G11 probably needs to be serviced. If your under warranty and you didn't drop it or get it wet, send it to Canon. If you're out of warranty or caused the problem, send it to: www.camerasandparts.com If you have to pay, they are generally half the price of Canon and they do amazing work. They service the Canon Powershots exclusively, they're great if you need some help with one of these.
Press
the MENU-button to activate the OSD window (Figure 4).
Press
or
to
navigate through the functions. Once the desired function is
highlighted, press the MENU-button to
activate it. If the
function selected has a sub-menu, press or
again
to navigate through the sub-menu functions.
Once the desired function is highlighted, press MENU-button to
activate it.
Press
or
to
change the settings of the selected function.
To
exit and save, select the exit function. If you want to adjust any
other function, repeat steps 2-3
