SOURCE: Logitech Quickcam Orbit Sphere MP
Please read THIS article from Logitech regarding this issue. Make sure that 'Canecl Echo' box has been checked in the software under "Audio Settings".
Also make sure that you have the latest QuickCam software - v11.5. You can download it HERE.
Hope that helps!
If your issue is
not resolved, please do not assign a rating just yet. Please post back as
to what steps you took, results, etc, and I will try to assist you further as
best I can. I am here at your service.
P.S. -You can rate this solution with one of
four votes (remember that at times a bit of to and fro dialogue may be
necessary to resolve an issue).
Thank you for using FIXYA!
IrishDruid
SOURCE: Logitech Quickcam Chat - no sound recording!
At the bottom right of your screen, you should see an icon for volume. Right click and select Open Volume Controls. Click Options > Properties > recording and make sure all the boxes are checked. Click OK and make sure all levels are maximum and nothing is muted.
Next, right click the volume icon again, and select Adjust Audio Properties. Go to Audio tab and then Voice tab and select the appropriate recording device from the drop down menu.
By the way, your camera will only show up under Imaging Devices in the Device Manager and not under Sounds,Vidoe and Game controllers.
Hope that helps!
If your issue is
P.S. - You can rate a solution with one of four
ratings as explained under (remember that at times a bit of to and fro dialogue
may be necessary to resolve an issue).
IrishDruid
SOURCE: No video when using quickcam pro 9000 on google chat (gchat)
I had this problem but I fixed it. The google chat uninstaller does not uninstall everything. Go to the hidden folder Application Data of the default or local user in the Documents and Settings folder of the C drive, you will find the plugin folder for google chat. Delete it and then reinstall the plugin and it will work.
C:\Documents and Settings\Joe\Application Data
SOURCE: Cannot get the vidieo chat working on gmail with my new logitech
Firefox has nothing to do with the operation of your webcam.
Follow the instructions below and it will work.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program.
When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
2. Then click on the Video Settings.
3. The camera if Installed Properly will come up and show a video picture.
4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
1. Go to Messenger at the top left and click on it.
2. Next go down to Preferences and click on it.
3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
3. Next go to the Menu Bar on right side, click on “ “Action.”
4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger
1. On the VIM sign-in window click on Edit.
2. Then click on Settings Enhanced IM.
3. Next click on Enhanced IM.
4. Then click on Audio Video.
5. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
Notes:
· The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts.
· images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
SOURCE: Logitech 9000 out of focus...
Thanks rcodrix! I had the same problem and it got solved after following your steps.
More details of Step 2 given by rcodrix -
Once u remove the back cover, you will come across the pcb with small chip on it, carefully remove the 4 screws attaching the board to casing. The board also contains the camera lens. Remove the camera casing (small black cuboid..didn't have any writing on it as described by rcodrix though) and turn the lens to adjust the resolution. put evrything back.
