If you can tell us what the Os do you use, I think I can help you reset windows password better.
Do you know Windows Password Reset ? You can use this tool to create a new reset disk to recover the forgotten password. All systems support !
You can found the source in http://www.windowspasswordreset.net
Don't worry when you forgotadministrator password. Irealize an easy method to removewindows password, itneed no computer skills and no reinstalling windows. Google Windows Password Seeker or passwordseeker.com. Maybe thiscould help.
I lost my windows admin passwords few days ago. I solved the trouble with the help of windows password reset tool. It not only support XP/Vista/2000/NT, but also compatible with windows 7.http://www.reset-windows-password.com
Forgot Windows password? Try SmartKey Windows Password Recovery to recover lost password easily.
Four steps can help you reset the lost Windows 8/7/vista/xp/2008/2003/2000 password:
Step 1: Download Windows Password Rescuer/Windows password recovery tool on any available computer you have access to.
Step 2: Install Windows Password Rescuer and run it to burn a bootable CD/DVD or USB flash drive
Step 3: BIOS setting of your locked computer to set it boot from CD/USB.
Step 4: Insert the newly CD/USB to the computer.Reset Windows password successfully after Windows Password Rescuer starts.You also can use Windows Password Rescuer to add a new user with administrator privilege to your Windows. With this New user account you can logon your locked computer directly.
More details about the usage: http://www.daossoft.com/documents/how-to-use-windows-password-advanced.html
or http://www.daossoft.com/windows-7-password-recovery/how-to-use-windows-7-password-recovery-tool.html
WindowsPasswordBreaker can help you remove your forgotten Windows password by creating a password reset CD/USB.
Reset Windows Admin Passwords safely, I recommend windows password reset tool. Windows Password Reset 9.0 not only the operation is simple, but also compatible with all windows, it works perfectly to recover Windows Passwords.
Well, forgot Windows password? It is an annoying thing that I have troubled. And I would like to share with you some methods for recovery. 1. use a password reset disk if you have created before. 2. an available admin account is also a helpful way. 3. take a Windows password recovery tool, like Windows Password Unlocker, which is an efficient tool for that.
Forgot windows password is a common program, you can now use a password reset program to remove the password, that is the simple and best way.
If it's a windows 7 or Vista it should let you reset the password anything older than them then you have no hope but to re-install or install vista/7
