Controller FireWire VIA VT6306 Fire II IEEE1394 Host Controller
The first set of drivers contains the PCI drivers, USB drivers, AGP slot, as well as few others. That set will initialize the PCI controller to work. Your Firewire card won't work until that gets installed.
Once that is complete, you need to install the firewire drivers. That is what the second like is all about. Once that is installed, restart your computer and it should be working again. If the drivers aren't working from the second link, you may need to purchase a new Firewire card for your computer.
Usually when you install the 4 in 1 drivers, the computer will look at the existing hardware plugged into the the computer and try to install drivers off of that using plug and play. If it doesn't find them, it will look for the CD that came with your computer or hardware device.
