Roland Cube-20x (20w 8" Modeling Guitar Amp) Logo
Posted on Aug 28, 2011
When i plug my guitar in to my roland cube-20x it makes noise but doesnt pick up my guitar. i have pluged my guitar into another amp and it works so its the amp not the guitar.
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Dec 13, 2008
SOURCE: Getting Static noise when plugged in to amp
This is a very common problem that I have repaired for many friends. Sometimes the guitar jack becomes loose and gets rotated to the point where the wire breaks and/or touches the cord plug when it's inserted into the jack. You need to remove the access plate/panel at the back of the guitar body and see if the wire is broke or twisted. You may only have to loosen the jack retaining nut and rotate the jack to get the twist out or you may have to remove the jack and resolder the wire back in place. If its broke make sure to solder back on the proper terminal--the one with solder already on it and not the one that the cord plug touches when its inserted. Retighten the jack nut by firmly holding the jack from access side so it doesn't rotate again and cause that undesirable STATIC sound. Hope this helps.
Robert Graf
  • 269 Answers
  • Posted on Jan 24, 2009
SOURCE: Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Anonymous
  • 161 Answers
  • Posted on Mar 19, 2009
SOURCE: electric guitar pick up doesnt work?
se3veral things have to be ruled out, start with the cord that your using to your amp, is it good? next is the volume on both the guitar and amp also good, the last thing that should be wrong is the pickup itself unless a wire is broken off of it, you can usally check this from somewhere on the back of the guitar, if all the wires are good, check the two volume controls and on the back of the amp check the wires going to the speaker.
Anonymous
  • 192 Answers
  • Posted on Apr 13, 2009
SOURCE: Marshall MG10 cd guitar amp picks up radio frequency?
First of all I would call the radio station and let the know that there over modulating just a bit.this has happened to me a few times even on my tel/phone. I use to get WOKO on my amp. You can try and move the amp to diffrent location , reverce the polarty switch on the back , not much more you can do. But watch out when you here music comming from you toster your in big trouble, just kidding. Good luck DFD
Anonymous
  • 10 Answers
  • Posted on Aug 11, 2011
SOURCE: Amplifier not working
It is more likely that your input jack component is broken or damage you would have to take it apart because your circuit board may need a look at to check for damage and you will need a new input jack
Roland Cube 30 Bass Amp won't turn on?
1. Check the power cable and ensure it is securely connected to both the amp and the power outlet. 2. Check the fuse and replace it if needed. 3. Check the power switch and ensure it is in the correct position. 4. Check the battery (if applicable) and replace it if needed. 5. If the amp is still not turning on, contact Roland customer service for further assistance.
Hi my Roland cube 80xl makes a load noise when switched on without guitar plugged in. Noise is so loud can't keep it on.
I think the jack cable is not good try to buy a new one and see if it makes the same noise
Roland troubleshooting
Are the speakers hooked up? volumes up? Is the guitar using active pick-ups? if so, is the battery good? is any noise coming thru the amo?
Roland Micro Cube Amp fuse blew out. How do you fix it?
have a look here:
http://www.ehow.com/how_8698510_fix-roland-cube.html
although it doesn't mention the fuse you will probably find it. Sometimes there is a fuse access on the outer case.
2answers
Input jack fell inside
Yes, the jack MAY actually be broken. It will need to be serviced. Run cables through the handle to avoid plugs from being yanked sideways and breaking the jacks.
The unit input voltage is 110 volt and was plugged into 220v outlet. . the input winding is now busted. . i was hoping to know the secondary voltage of the transformer. . i was planning to replace the...
The winding is center tapped. It generates +/-24.5 volts DC. Based on it being a capacitor input filter, we need a peak voltage about 1 volt higher to account for the droop of the capacitor and the .7 volt drop of one silicon diode...
Since we need 25.5 volts peak then we need that divided by 1.414 RMS out of ONE side of the center=tapped secondary... So our secondary voltage is 18 volts either side of center.
You will need a 36 volt center-tapped secondary. Here is one that would work:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=162J36-ND
This has two 18 volt windings that you would connect in series and a dual primary you can set for either 120 or 240 input. About $19 US.
2answers
The Cube 60 is a guitar amp, Often these problems are due to a damaged inout jack on the unit. People trip over the guitar cable and the cord gets yanked sideways and breaks the internal parts of the jack. Sometimes circuit boards are cracked.
ALWAYS run your cord through the handle or restrain it should the cord be yanked.
The problem with your unit is internal and it will need to be opened and trouble shooting done.
Dec 15, 2009 • Music
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
